SOURCE: 2005 Nissan Exterra won't start
Run a jumper cable from your positive side of battery. to your starter incomming large post...be careful....It will spark big time. If the started ingages your selenoid is cooked and needs to be replaced. Be real careful or you can cause harm to yourself as well as your car
SOURCE: gear of starter motor won't engage in flywheel to run the tractor
Look under 'My Profile' (Longhorn294 in the top right corner of this page)on page 5 at this post and solution. "craftsman riding mower starter will spin but not engage". Dwain
SOURCE: If the ignition switch fuse, starter relay,
Here are some possible reasons:
Park/neutral switch is open.
Poor ground connection to starter.
You can test the park/neutral switch by either jumping the solenoid (connect the hot terminal to the start terminal to see if the starter cranks--if it does, the ground is good) or by interrogating the starter relay socket. To interrogate the relay socket, use a 12 volt test light connection the clip to battery positive. Probe the socket terminals with the test light. If only one terminal lights the light, your park/neutral switch is bad or the start wire to the solenoid is bad.
SOURCE: Toro/Wheelhorse Tractor wont start
AS YOU HAVE CHANGED ALL OF THESE COMPONENTS TO NO AVAIL IT HAS TO BE A BREAK IN THE WIREING ITSELF, YOU WILL HAVE TO FOLLOW THE WIREING WITH A MULTI METER TO FIND WHERE THE POWER IS LOST.
SOURCE: starter motor spins won't engage flywheel on lawn tractor
take it off and see if the gear is broken (you can buy the gear at napa)or did the shaft the gear rides on got a little rusty over the winter
