Question about Craftsman Garden
Hello, I am looking for instructions or video on how to replace my attachment lever assembly on my Craftsman lawn tractor 917.259566 I already have the part pn 154809 I hope you can help
    New Friend:
  • 17 Answers
Type in your what you are looking for and put youtube behind it and you will find your answers.
Posted on Oct 08, 2019
Testimonial: "I have searched youtube and can not find"
6ya staff
SOURCE:
Anonymous
  • 49 Answers
SOURCE: mounting snow blade to lawn tractor
It attaches the the front of the tractor. Similar to a plow to a truck. If you don't have the brackets, you will need those, or make your own. You can see a picture of the brackets if you go to sears.com. Click on the PartsDirect link at the top, and enter the blade model number.
Posted on Feb 05, 2009
wadembly
Wade Mobley
  • 513 Answers
SOURCE: Craftsman lawn tractor model new battery drains quickly...
it could be the stator in the engine check the voltage with the volt meter when its running if its low check connections on battery & voltage if its below 12.5 volts then its the stator but the only thing is the engine should run with-out the battery so there is something else going on there is a fuse in the electrical system if theres a short that fuse will blow & engine will stall
Posted on Jun 08, 2009
Dwain Pippen
  • 376 Answers
SOURCE: need to adjust brake/clutch 14hp craftsman lawn tractor
The brake is on the right side of the transaxle. There are two mounting bolts and one 1/2 nut in the middle that is your adjustment. Tighten it 1/2 turn at a time and hold the brake down and try to roll it until it holds.
Posted on Jun 09, 2009
Dwain Pippen
  • 376 Answers
SOURCE: large belt routing for crafstman lawn tractor
Go to... http://www.searspartsdirect.com/partsdirect/index.action Enter the model number that is under the seat. If it's a lawn tractor, it will start with 917. That will get you to all the diagrams of the mower.
Posted on Jul 02, 2009
Mike McDowell
  • 148 Answers
SOURCE: Blades won't disengage
When the mower is off and the clutch is disengaged you should not be able to physically turn the blade(s) if you can then you need to adjust the blade brake (look on the mower deck and you should see what appears to be a brake pad). Your owners manual will show you how to adjust. If you need a copy of the owners manual then I would suggest going to www.managemyhome.com and downloading a free copy of the manual for your mower (Need model number which starts is located under the seat).
Posted on Jul 27, 2009
Replacing a mower brake tension spring
Mower Brake Return Spring Replacement - Craftsman ...
? 2:15
www.youtube.com/watch?v=kyuE5NBR5xU
Jul 31, 2014 - Uploaded by RepairClinic.com
This video provides step-by-step instructions for replacing abrake return spring on Craftsman riding lawn ...
Oct 27, 2015 | Craftsman Garden
Craftsman lawn tractor blade lever won't disengage
you either have a broken or missing spring that retracts the engage pulley or there is dirt or debris under the arm on top of the deck that the pulley is attached to.
Jun 14, 2014 | Craftsman 20 Hp 42" Deck Lawn Tractor
I need to replace the steering spindle and front axle for my craftsman lawn tractor, 18.5 hp, 42in deck, model #917270760. I'm not able to find a shop manual or any instructions on how to do this. Any...
You can find your manual at:
http://www.managemylife.com/mmh/owner_manuals/16827/CRAFTSMAN-Lawn-Tractor-L0030155?brand_name_search=917270760+CRAFTSMAN
Parts are available at www.searspartsdirect.com
You won't find detailed instructions there, but there are parts diagrams that will help you determine what to remove first. I can't imagine why you'd need to replace this whole assembly, but the diagrams should be helpful.
Sep 24, 2010 | Craftsman Garden
Starter gear doesn't move up to engage flywheel gear when started
The solenoid does two things -- it closes an electrical contact to run the starter motor, and also pulls a lever to slide the motor gear up to engage the flywheel. Since the contact is closing, the solenoid itself must be OK, but the lever could be broken, or the sliding gear could be binding or stripped. Since you're looking at a probable replacement, try cleaning with compressed air, then squirting some WD-40 into the starter gear area - you could get lucky! Otherwise, you can replace the starter/solenoid assembly -- you can find replacements on eBay for about $80. Less expensive but more time consuming is to remove the assembly, disassemble, and replace just the defective parts if you can find them. Good luck! Please rate my answer if helpful, thanks.
Jul 15, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
The mower deck clutch cable broke so blades will not engage and lever is loose on my Sears Craftsman 42-inch lawn tractor (917-271-742). I fished out the top piece of the cable, about 12 inches down to a...
I just got the kit 175067. Have the old one off except for where it's attached to the lever, schedule and weather has kept me from going further. Very simple to reconnect things at the pulley and above but not too sure how to connect the rest onto the lever and haven't had a chance to get a good look at how the old one might be connected yet. Should be a simple fix.
Jun 20, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Engine stops
Hello
Have a look at the saftey switches.theres one under the seat.and one under the blade engage lever.
There may also be one under the hood near the fuel tank.
May 04, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How do i replace the lift shaft assembly on my craftsman lawn tractor? model number 917.272442.
there is not enough space here to describe the replacement procedure. some helpful tips though - order the part you are replacing [ordering from sears tell them: division 71, source 917, part no. 159471] before you tear into it. sitting around for 3 or 4 weeks, you'll probably forget where things attach. also, find the exploded parts diagram in your owner's manual and look it over carefully to see what you're getting yourself into. sometimes, it's worth a few bucks to let a competent shop do the work
Jul 14, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
Top Craftsman Garden Experts
john h
Sheldon Dedek
rjivaro
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
