Question about Sony Office Equipment & Supplies
I HAVE A SONY CX1 PRINTER THAT PRINTS ALL YELLOW OR ALL BLUE WHAT IS WRONG?
6ya staff
SOURCE:
Anonymous
SOURCE: dear support,
i got some advice free...... warranty
Posted on Apr 13, 2008
Anonymous
  • 30 Answers
SOURCE: Ink Cartridges
If is an original brand? Some generic cartridges or refill ones gave that problem.
Posted on Aug 19, 2008
Anonymous
  • 81 Answers
SOURCE: My printer prints in the wrong color!
Check to see if the correct colour is in the correct place in the printer. You may have the Cyan and Magenta mixed up
Posted on Aug 22, 2009
Alen
  • 58 Answers
SOURCE: HOW DO YOU CHECK INK CARTRIDGES TO SEE IF PRINTER
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01291990&tmp_task=useCategory&lc=en&dlc=en&cc=us&lang=en&product=3795406
You can find instructions on the link above
Posted on Jun 19, 2010
Eric Sandbo
  • 159 Answers
SOURCE: My mfc-3220c printer only prints
If ink has dried and clogged the printing nozzles, it might not be savable, but we can try.
Press the INK button and tell it you're changing ink, then open the cover. With the printhead carrier in the middle of the machine, unplug the power. With the power off, you can slide the carrier by hand. Move it left to give you room to clean the cleaning mechanism on the right. It's dark black in there, but with a flashlight you can see the rubber seals that get pressed up against the printhead to keep it from drying. Clean those seals and the rubber blade that wipes across the heads. Use a cotton swab (Q-tip) that's sopping wet with plain water. It's important that you don't leave any cotton fibers behind. Those can allow air to get past the seal, drying out the nozzles again.
Leave those rubber parts wet as you close the machine up and power it on again. Use the INK button to run the machine through 3 or 4 cleaning cycles. It's going to blast through a fair amount of ink, but might save the machine. Try a test print.
The water on the rubber wiper may have caused some ink to mix into the wrong nozzles, causing the colors to come out wrong. More cleaning cycles and use will clear that up.
If one or more colors still don't print at all, you probably have a bad printhead, and replacing that would cost more than a replacement machine. If you're missing just a few nozzles now, it might clear up with more cleaning cycles. Sorry about all that ink going to waste.
If you're desperate enough, you can try cleaning the printhead manually. Again, use the INK button to move the head to the center of the machine, then unplug power. Remove all 4 ink cartridges.
On each side of the carrier, you'll see a long, black, wire spring that holds the printhead into the carrier. Push the bottom end of each spring down and back to unhook it, then lift it outward and up, so it points at you. You can move the carrier side-to-side by hand to make access easier while you do this. Now the printhead (the box assembly you mount the inks into) lifts out of the carrier.
Being careful to get as little ink on you as possible, flip it upside-down, and you'll see the brass plate with the hundreds of microscopic holes that the ink squirts through. Try cleaning that with more sopping-wet swabs. A little glycerin (from a drug store) in the water may help. Keep your fingers off the nozzles, for the sake of your cleanliness and the nozzles. Keep fingers off the electronic contacts on the back of the printhead. Be VERY GENTLE cleaning the print nozzles. They're so tiny that even a q-tip can damage them.
When putting the printhead back in, rock it into place, then press it firmly toward the back while clipping the springs back into place. Put the inks back in and run more cleaning cycles.
Good luck.
Don't get carried away trying to clean the inside of the plastic covers in your machine. Everything in there is covered with a mist of dried ink droplets. Since they were almost dry when they landed against the plastic, they're not too noticeable, but as soon as you get them wet, they spread in a dark, black stain. You can spend hours and go through a dozen rags trying to get it all clean again, and as you get more an more ink on your hands, you spread it to the outside and everything around you.
If you get ink stains on your hands, it's not a big deal. The ink is water-based, and while it may soak in too deep to wash off with soap and water on the first try, it will be gone in about a day.
Posted on Dec 04, 2010
Printer prints wrong colors?
put the printer in calibrate mode
Apr 06, 2015 | Office Equipment & Supplies
Dell 3100cn prints the wrong colors
Go to Control panel
Click on: Hardware and Sound
Click on: Devices and Printer
Click on your printer
Click on Adjust printing preferences
Then go to the Maintenance Tab at the top (should be last tab)
Then click Print a test page
You can also Align Ink cartridges from here and clean the Ink Cartridges
If that does not work then update the drivers:
Go to Start
Type in box Device Manager
Click on Device Manager in list
Wait till list populates.
Click on Imaging devices
Right click on the printer
Update the drivers by searching online
Apr 03, 2013 | Dell Laser Printer 3100cn PCL6
When printing a photo has a yellow/green tint. All other functions work it prints and scans great. Just have a problem with printing photos.
Possibly it is running low on Blue ink - because colors are usually a mixture of inks - for example green is made from blue and yellow - if an ink runs low it will print the available colors or substitute the next available color.Probably if it prints green yellow - then it has no blue available to make the right shade.
Oct 26, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Hi Ihave a MP-500 that prints off color.
You need a new printhead, QY6-0059-000, around $60.00. They do wear out and also plug when you use generic inks.
Oct 23, 2009 | Canon Pixma MP500 All-In-One InkJet...
Ink Cartridges
Jul 06, 2008 | HP DeskJet 5150 InkJet Printer
Canon IP4300, Yellow prints as green. And all colors prints blue
makklodge:
1. Replace your Ink cartridge with original Ink. (yellow problem is Black catridge problem.
2. Clean your Printer Head using with ISOPROPHYL ALCOHOL.
MrScared
Mar 29, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
A yellow blob in the middle of the Screen
Recently, I had exactly the same problem on my VPl CX1 but also found the solution on the web. It is overheating. I cleaned the filter that is underneath the projector and also raised it slightly (resting on the lens cover and rear stand) for better air flow. Problem solved...at least for me.
Sep 21, 2007 | Sony VPL CX1 Multimedia Projector
16 people viewed this question
Top Sony Office Equipment & Supplies Experts
jasbo
jasbo
Eric Rotmil
Eric Rotmil
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
