SOURCE: Thread Breaking On Brother Sewing Machine
if thread is good quality you may have a sharp groove in your needle plate hole from needle breakage. if so, polish with emery tape.
scott
SOURCE: How to thread a Brother cs-100 sewing machine
Please follow the link below, for the manual
http://welcome.solutions.brother.com/BSC/public/files/dlf/doch000207/cs100ex660qg01enfres.pdf
SOURCE: Hello there i have a singer 8618 electronic sowing
Call singer at 1-800-4singer at customer service, be patient and wait, sometimes you may be on hold a little while but it is worth it.
SOURCE: I have a Brother Lock-524N Surger, I need help to
Check out Brother site for 634D improoved one and very helpful for me.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_634D_EN_1240.PDF
SOURCE: Brother VX-1120- The needle is not picking up bobbin thread.
I had the same problem with my brother vx-1120 sewing machine. I set the needle to lowest position by using the hand crank. Then I loosened the knerled set screw that holds needle in place. Then I moved needle shaft till the eye of needle is just lower than the hook on the shuttle loop maker. It made my mechine work. There are instuctions for ajusting timing on machine but I think these mechines are built to not fix and throw out. Just because there where no ajustment marks at all on machine, any machanical machine will needed to be ajusted sometime.
