Want to adust scope more but it,s at the the end of adjustment for the left
SOURCE: beeman RS2 model 1074 pellet gun
i found a guy online and he was able to help me.not sure if i can tell how or who helped me so i better not. thanks anyway
michael
SOURCE: unable to zero in on target?
take it in because if he bumped the rail the scope is on it can make it inaccurate
SOURCE: i have a nikon 3x9 rifle scope. im shooting about
It will stop but don't turn to tight or cross hair will break, but You should never have to adjust that much 12 clicks should do it
SOURCE: How do I adjust my scope on my Crossman bb/pellet rifle .177
Assuming the scope is ok, and the gun is ok, it must be the shooter, Not you but the stance, holding, bench rest, something is not consistent. If I was you, I would set up a big piece of cardboard at 15 yards, get the rifle on a beanbag or a bench rest, aim at a one inch spot in the center of the cardboard, shoot about 3 times, depending on where the pellet is hitting, move the adj knobs accordingly, do it again, 3 times, adj, as many times as it takes, get it centered, then, shoot it about 3 times at a clean plate, if it hits it's mark 3 times, then you can try it standing, and you should be able to build confidence in it so you know where it shoots, and won't be discouraged. Now if the rifle is bad, or the scope mounts loose, you will fight the thing all day and end up trashing it. I would blame the mounts first, then the scope, then the rust spot in the barrel, rare. If it is a break action rifle, you can set it up in a box with v's cut into it, look through the bore at the target, make sure it doesn't move, the scope should be looking at the same exact thing, if it isn't, something is wrong. You can set it up this way to start, and then fine tune it with pellets. Check it out, hope this helps.
SOURCE: installed a new scope on
normaly this is a mount problem,,,,but undo the eye end scope screws and slip under the scope 3 strips of 35mm film then nip the scope back down this will tip the scope front down and life the point of aim up,
