Hi Jill, indicate brand, model and type of equipment you are commenting on, in order to find the best possible solution
I wait your answer
Regards Franco Dosil
Hola Jill, indica marca, modelo y tipo de equipo del que estas comentando, para poder encontrar la mejor soluci?n posible
Espero tu respuesta
Saludos Franco Dosil
SOURCE: Blue patch on left side of screen
I had the same problem with my Hitachi PJTX100. I discovered that there was considerable dust build-up inside the unit, causing insufficient venting of heat which then damaged the color prism/filter. It was close enough in time to the warranty for Hitachi to cover parts replacement (approximately $1,600). Since the repair, the blue patch is gone. I also regularly vacuum not only the outer cover but also the inner air filter that easily snaps on and off.
SOURCE: blue haze on my plasma screen
The driver boards on that side of the set need to be replaced, about $400 for parts.
SOURCE: Seeing double on the left side of the screen red on top and blue on the bottom
convergence problem you will need to stk ic and some resistors
SOURCE: Blue Haze
What needs to happen is three specific voltages need to be adjusted on the power supply, You need to set the Ve voltage to 100v, the Vset voltage to 188V and the Vs voltage to 190v. Monitor the set for 24 hours, if haze doesn't come back the unit is considered repaired. If haze returns, then the problem is with the panel itself and wouldn't be worth it to replace because it will cost more than the tv cost you originally
