SOURCE: Clarion DXZ838RMP CD Player
Here is the link to the user manual for your player if you need it;
http://www.clarion.com/gb/en/MungoBlobs/...
Page 38 of the manual (page 42 of the pdf file) describes the error codes
error 6 states "a disk is loaded upside down inside the cd deck and doesnt play properly"
Suggested solution is to try the disc the other way up, if this doesn't help then there is most likely a problem with the lens - possibly cured by cleaning, please ask again if you want to try this yourself and we can talk you through it
pls - check also that the cds you where trying to play were of the correct type, and burned in the correct format, also that the settings are correct for the type you are using - page 21 (25 pdf)
Next thing to try is cleaning the lens - use a cotton bud which you have dipped in alcohol - rubbing alcohol is ok - but let the cotton bud dry mostly before going at the lens.
Figure out how to get to the lens and very gently wipe it with the cotton bud.
Remember the lens is not that scratch resistant, and it is quite finely positioned, so wipe, dont scrub.
If that doesnt help, then check that there is adequate voltage to the unit - it may have enough to appear to function but not to initiate the laser - bad ground cable would be the first suspect.
If no luck with that, then i think the set needs to be serviced properly - sorry
if you need help finding a service centre let me know with your general area
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
SOURCE: Lens Knocking Against The CD - All CDs skip or diginoise then fail.
Take the small back cover off and take some electrical grade contact cleaner and spray all around the lens area, that worked for me.
Mike
SOURCE: 1998 astro van, makes fast clicking noise won't start
Triple check your battery cables on the battery end .. esp the positive + side.. Side post batteries are notorius for that
SOURCE: Car CD player plays but has no sound
Does your car have a premium sound system? Assuming that your cd deck is fine, try connecting your remote turn on wire from the sony to the corresponding wire on the car(if you bought a wiring harness, just match colors). Also some chryslers used a ground to turn on the amps.. a black wire with a female connector as well as a heavy ground ribbon cable... connect those 2 AND the ground to your stereo to enable the amplifiers.
SOURCE: 2006 Humer H3, Won't start and electrical resets itself
Check the battery terminals real good.Make sure they are clean and tight.Check and see if any of the side terminals are leaking. As far as the blower motor.It is more than likely that the blower motor resistor is bad.It is located by the blower motor.Hope this helps.Good luck.
