Televison & Video Logo
A
Anonymous Posted on Oct 05, 2019
Sony tv removal
How do I get to the back of the tv to plug in a HDMI cord?
dish guy
Level 2:
Scholar:
New Friend:
  • Sony Expert 82 Answers
  • Posted on Oct 06, 2019
dish guy
Sony Expert
Level 2:
Scholar:
New Friend:
Answers
82
Questions
0
Helped
33523
Points
310
Run the make and model on google, if its older it wont have them. They should be pretty readily apparent on the back of the tv
3 Related Answers
Anonymous
  • 14 Answers
  • Posted on Dec 13, 2007
SOURCE: Onkyo TX-SR605 Receiver HDMI Issue
How good are the hdmi cables that you are using???
Oliver
  • 132 Answers
  • Posted on Nov 18, 2009
SOURCE: My PS3 will not play sound on my Sony Bravia
Adjust the system's audio output settings. These settings are mainly used when the system is connected to audio devices that support digital audio output, such as AV amplifiers (receivers) for home entertainment systems.
1.
Confirm the formats supported by your audio device.
Settings vary depending on supported formats. For details, refer to the instructions supplied with the audio device.
2.
Select in_soundset.gif (Sound Settings) under in_setting.gif (Settings) in the home menu.
3.
Select [Audio Output Settings].
4.
Select the input connector on the audio device. Channel numbers and audio formats that are supported vary depending on the connector in use.
soundoutput001.jpg Input connectors on the TV or AV amplifier (receiver) PS3™ system output connectors Channels that can be used for output 2 Ch. 5.1 Ch. 7.1 Ch. HDMI HDMI OUT connector in_maru.gif in_maru.gif in_maru.gif Digital Out (Optical) Digital Out (Optical) connector in_maru.gif in_maru.gif - Audio Input Connector / SCART / AV MULTI AV MULTI OUT connector in_maru.gif - - 5.
Select audio output formats.
Select all output formats that are supported by the audio device in use. If [Audio Input Connector / SCART / AV MULTI] is selected in step 4, the screen for selecting audio output formats will not be displayed. If [HDMI] is selected, you can also select to automatically set the audio output format. (In this case, the HDMI device must be turned on.)
soundoutput003.jpg 6.
Check your settings.
You can go back to the previous screen and revise the settings by pressing the in_left_key.gif button.
soundoutput002.jpg 7.
Save your settings.
The audio output settings are saved on the system.
Hints
  • [Linear PCM 2 Ch.] audio is set to be output from all output connectors by default. If you change the audio output settings, audio will be output only from the connectors that were set.
  • If you change the audio output settings, the system will no longer be able to output audio from multiple output connectors at the same time. For example, if your system is connected to a TV via an HDMI cable and to an audio device via a digital optical cable and you switch to [Digital Out (Optical)] under [Audio Output Settings], audio will no longer be output from the TV. To output audio from the TV, switch the setting to [HDMI], or select in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Multi-Output] and set the option to [On].
  • If you select [Linear PCM 2 Ch. 88.2 kHz] or [Linear PCM 2 Ch. 176.4 kHz] in step 5, sound may be intermittent or may not be emitted from some audio devices.
  • When using an HDMI cable, only [Linear PCM 2 Ch.] audio will be output from PlayStation®2 and PlayStation® format software. To output Dolby Digital or DTS audio, you must connect the PS3™ system and the audio device using a digital optical cable and switch to [Digital Out (Optical)] under [Audio Output Settings].
  • If a device that is not compatible with the HDCP (High-bandwidth Digital Content Protection) standard is connected to the system using an HDMI cable, video and/or audio cannot be output from the system.
(Information taken from here)
Hope it helped.
Anonymous
  • 6771 Answers
  • Posted on Mar 28, 2012
SOURCE: my new sony hdmi dvd player is playing sound but no pix. why?
I would take the player right back to the place of purchase, it is clear this is a manufacture issue.
When i unplugged the cable hdmi and plugged it back in the tv turned off. Now everytime i plug in the hdmi cord the tv turns off.
Some sets and devices have HDMI control that can turn off and on devices connected to them. Look into the settings of both devices and search for anything to do with HDMI control.
Sony Bravia built in DVD player wont accept the discs - why is this?
Performing a power reset
1. Turn off the television.
2. Unplug the television power cord from the electrical outlet.
3. Let the television remain without power for 60 seconds.
4. Plug the power cord back into the electrical outlet.
NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
5. Turn on the television.
How to establish an HDMI connection between a TV and other device.
Follow the steps below if the HDMI® connection between your TV and other device is not working:
1. Make sure both the TV and other device are turned on.
2. While turned on, unplug the power cords for the TV and device from the electrical outlet.
3. Disconnect the HDMI cables from the TV and other product.
4. Wait 60 seconds.
5. While the HDMI cables are disconnected, plug the power cords back into the electrical outlet.
6. Turn on the TV.
7. Re-connect the HDMI cables.
8. Turn on the HDMI-connected product.
The TV should now detect the HDMI signal from the connected device and operate normally. If there is still a problem, disconnect the HDMI cable from both products and then reconnect it in the opposite direction. In some situations this has been reported to resolve connection issues.
How to reset a TV to factory settings: https://us.en.kb.sony.com/app/answers/detail/a_id/61396
Hopefully this post helps you! If does, please mark it "accept as solution"
6helpful
The word debug is on the screen. how do i take it off?
Unplug the power cord of the receiver box for 10 seconds and then plug it back.
How to connect my hdmi from my msi u 230 to lcd 32" tv
on the back there should be a HDMI plug right by your monitor plug. you plug in the HDMI cord and then you plug it in the TV's HDMI plug. then switch to HDMI channel on your tv
Yesterday, i played my PS3 on a hd tv using the hdmi cord for the first time, then when switching back to a regular tv and using the red, white , and yellow rca cord, the ps menu didn't show?
There are a few ways to remedy this situation.
1) If you have access to that HDMI port on the TV, plug it back in and switch the settings back to composite. Your screen will go black which means you did it right.
2) I've only done this once and it was a trial-by-error step. Plug it into the tv, turn it on, hold your finger over the power button to turn it off. Hold your finger over the power button when turning it on. After a few cycles it worked for me. Key thing is to keep reseting it.
The safest thing to do is get the HDMI tv to switch your settings back
My screen wont work i tried a hdmi cable but wouldnt work what do i do?
If you can get a display with the default setup (original cords) follow this procedure:
a) Plug in BOTH the HDMI cord and the other display cords to your TV.
b) On your TV, using the disignated video input (not HDMI) you should have the main screen
c) Go to settings, and then display settings. Set up your display to read HDMI. Your screen will go dark.
d) Quickly change your TV input from video to HDMI and it should still be displayed. Save the changes.
e) Shut off the system, unplug the original cords leaving in just your HDMI cord and your designated audio cord (preferably fiber-optic).
f) Turn it back on and you should be good to go.
Need Help
try connecting A/V rca cable first. go to ur diplay settings and then to video output settings in it select av multi. don't use HDMI settings let it automatically ask u when u plug in hdmi cable. Then switch to HDMI cable. I had a problem like this before with a ps3 that i had bought used. hdmi was set up and it took forever to set it up with rca cords. took many times power on and offs and unplugging video cords for it to reset. . not sure. Now when u plug in your hdmi on any tv it should automatically set up. and you have settings for a/v as backup. the other thing is it could be the just the port or cable.
Can't watch dvds on playstation 3
No, but you do have to select HDMI output in the settings in the PS3 menu and make sure the TV is switched to the correct HDMI input ( Whatever one you plugged your PS3 into)
2answers
Playstation 3
try using the composite cables as well.....with your tv set to the composite input go back into the settings and select the HDMI output switch your tv's input back to your HDMI input and remove the composite cables....it should work fine...
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
