SOURCE: clogged fridge drain tube
The drain is behind the back panel in the freezer at the bottom. Sounds like it is frozen over which is pretty common. Will need to remove panel and thaw out drain by running hot water down. You can use a putty knife to break up ice first. Make sure you get all ice around the drain above and below the thin aluminum tray at the bottom. After the drain is free don't be alarmed if you get some water on the floor because the drain pan may not hold all of the water you ran down the drain. Not anything you can do to prevent this on this model.
SOURCE: Fridge water "overflow" ?
It is supposed to drain to a plastic tray under the fridge. There is usually not a lot of water that drips down there... and the water usually will evaporate before overflowing.
If the water is draining on the inside of the fridge, then the drain tube on the rear of the fridge might be clogged. You should be able to remove the tube fairly easily, and then see if you can blow air into it to see if its clogged. Sometimes it just gets clogged with dirt and dust. If the tube is clogged, and you cannot blow air through it, then see if you can get a small somewhat flexible wire and push it through the tube.
Hopefully it will make it all the way to the other side.
Hope this helps.
Good luck.
Mac =)
SOURCE: Maytag A512 Leaks out airgap when draining/spinning out
Check pump. I would say it is the most likely cause for the water leak, especially if itdoes it while filling and on spin as the pump holds some residual water in it . That is normal.
SOURCE: Water inside my Hotpoint Fridge/Freezer RFA70
There is a kit available, WR2X9393 which includes an aluminm heat probe which you attach to the heater to prevent icing of the drain
SOURCE: ice under freezer floor, water in fridge (drain clogged)
in the freezer remove the cover plate where the fan is an insert a pipe cleaner into the drainage tube opening.
