SOURCE: how to air bleeding in break system by step by
you need two persons
open the bleeder screw on the wheel that is furthest from the master cylinder and do the nearest last.
have a person pump on the brake pedal and hold firm while you open the screw, then close it before tell the person pump again
repeat until you see no more air come out
make sure you fill up the master cylinder, do not let it run out of fluid
SOURCE: hydraulic breaking system
My way is to start furthest from the master cylinder & work to the closest. Make sure the master cylinder remains toped up throughout the procedure. With any luck with the lid off the master you can gravity bleed it, ie: just crack the bleed nipple & fluid should start comeing out. Let the fluid bleed a little then tighten the nipple. Repeat for all for. If it will not gravity bleed let me know & i'll give you another procedure. Gravity is best though
