SOURCE: viper 5701 remote issue
sounds like the remots have lost two way communication. try to disconnect the windsheild antenna.try remotes again after pluging antenna back in.
SOURCE: I've got a "new" used
Hi, 1.Press ' asterisk ' on
the transmitter twice within 3 seconds. 2. The parking lights
will flash to confirm remote start operation 3.Once the vehicle has
started, it will run for the pre-programmed period of time (12, 24,
or 60 minutes) or until a shutdown input is triggered. This
can be set to minute increments by your installer. http://www.retrevo.com/support/DEI-561R-manual/id/552dj492/t/2/ Thank You
If you need the user guide
for this 561 R you can download from below website
SOURCE: Just bought a`used truck that came with a Viper
That remote can work with both a security system, and a combo unit security/starter.
Best bet is to take the vehicle and remote to your local Viper dealer and they can look the car over and tell you what was installed and help you learn how to use it.
Bad switches, contacts, fuses/relays.
