SOURCE: rear Projection Tv Problem! black and white... Please help
go into menu turn color off see if you have a black and white picture if not adjust red,green, and blue screen drive on controls in back of tv you have red, green, blue it will have focus /screen controls cover each tube do one at a time blue focus and screen drive adjust to clear blue picture do all 3 tubes, then adjust them to where you have a black&white picture once this is done turn color controll back on.Thank You for using FixYa and Have a Nice Day.
SOURCE: samsung series 5 500lcd tv just black & white colors.
thanks for rapid comm.resolved issue .stb is a old version ,does not support hdtv ,changed to a newer version,everything worked fine.once again thank u
SOURCE: My xbox appeared black & white in my tv monitor
There might be a problem with the jack inserts on the T.V. have you tried wiggling the jacks while there plugging in to the T.V. and also make sure the same cord is securely connected in the back of the console.
SOURCE: hy does a colored tv record in black and white on
I suspect that you have the video standard is incorrect. Ensure you are recording in the same format as the signal you recieve. IE: NTSC or PAL. Whatever but they should both be the same. IE: Signal recieved = NTSC Video recorder must be set NTSC as well. Same goes for PAL.
Hi marilyn meade, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
check color system setting is not matching TV BROADCAST type IE PAL >> NTSC or NTSC >> PAL
