A
Anonymous Posted on Oct 03, 2019
RESET OR REBOOT PIONEER VSX 515 - Pioneer Audio Players & Recorders
Franco Dosil
Level 3:
Top Expert:
  • Pioneer Master 10,542 Answers
  • Posted on Oct 17, 2019
Franco Dosil
Pioneer Master
Level 3:
Top Expert:
Answers
10542
Questions
0
Helped
377053
Points
178965
https://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/218219113VSX515OperatingInstructions.pdf
Ed PeeBee
Level 2:
New Friend:
  • Expert 42 Answers
Ed PeeBee
Expert
Level 2:
New Friend:
Answers
42
Questions
0
Helped
19562
Points
114
From the manual...
Resetting the main unit Use this procedure to reset all the receiver's settings to the factory default. Use the front panel controls to do this.
VSX-515 model:
1 Switch the receiver into standby.
2 While holding down the TONE button, press and hold the  STANDBY/ON button for about three seconds.
3 When you see RESET? appear in the display, press the ENTER button. OK? shows in the display.
4 Press SYSTEM SETUP to confirm. OK appears in the display to indicate that the receiver has been reset to the factory default settings.
5 Related Answers
Anonymous
  • 752 Answers
  • Posted on Sep 14, 2007
SOURCE: IT'S A PIONEER VSX-515
Either you plugged the TV outputs into the wrong input or you accidentally set it for the wrong Input mode (i.e. your using analog cables but it's set to look for digital optical).
Anonymous
  • 308 Answers
  • Posted on Mar 22, 2010
SOURCE: pioneer vsx-515 no sound from dvd player plugged
Its just a wire covered with a shield. You can ohm it out with a multimeter.
RobRocks
Rob Emerson
  • 69 Answers
  • Posted on Dec 14, 2010
SOURCE: Pioneer VSX-515-K A/V Receiver firmware
To download firware for your receiver click on the link below. I hope this helps.
http://www.givemefile.net/firmwares/_av-receiver/pioneer/vsx-ax3-k.html
Anonymous
  • 2992 Answers
  • Posted on Mar 21, 2011
SOURCE: I have a Pioneer VSX-515
Like many newer receivers, this model doesn't have a phono input. I guess manufacturers think nobody listens to vinyl today. You can still hook a turntable to one of the extra audio inputs on this unit, but you'll need a phono preamp. The output level from the turntable is too low to drive a "line level" input directly, and the preamp boosts and equalizes the signal so it will work properly. Radio Shack still carries a preamp; you can order online or find it in some of their stores. Many other sources are available online, and if you have a good stereo shop in your area they probably stock one. Plug the turntable to the preamp input, connect the preamp output to the receiver and that's it. You'll also need an AC outlet nearby as the preamp needs power.
Anonymous
  • 8546 Answers
  • Posted on Apr 20, 2011
SOURCE: I have a pioneer rec.
What model subwoofer would that be? The Pioneer manual would offer some guidance on ITS end of this partnership.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Pioneer-VSX-515-K-Receivers-manual/id/386ag000/t/2/
Am i supposed to be able to plug optical in to optical on my pc and get 5.1 surround sound with my pioneer vsx -515-s/-k.
That would follow. Assuming the PC's unspecified sound card (output) is set up to export the digital bitstream that the Pioneer can accept. Read some manuals.
I have a pioneer rec. vsx-515. I do not have the instructions how to hook up the main sub woofer that plugs into the wall
My VSX 515 jumps from CD to AM unexpected and this happens at irregular intervals, is there anything I can do.
I'd suspect another infrared transmitter in the vicinity. Try blocking the 'eye' on the receiver and completely hide all the remotes you know about and see if it stops.
1helpful
I have a Pioneer VSX-515-K A/V Reciever. When I plug it in the power relay clicks continuously. I don't have the schematic to troubleshoot the circuit. I just want to make sure it is the relay that's bad...
A bad relay won't pick and release itself. You need to find the cause.
Here's the Service manual.
http://www.kallhovde.com/pioneer/tricomp/Audio/VSX/VSX-515_RRV3092.pdf
Page 66and 67 have a timing sequences for power up and down.
Pages 72 and 73 describe a possible loops - DC abnormality and Fan Stopped.
Pioneer vsx-515 no sound from dvd player plugged into coax input.how do you check the coax cable?
Pioneer vsx-516 6.1 channels
Check the speakers one by one maybe there is one bad or almost damaged
DC level output
the output transistor is shorted, turn it off and have it serviced.
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
