Dryers Logo
Posted on Sep 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Maytag dryer model sde4606ayw ser 12775126ev will not heat heating element checks ok and vent is not pluged.
Anonymous
Level 3:
  • Maytag Master 3,361 Answers
  • Posted on Sep 16, 2009
Anonymous
Maytag Master
Level 3:
Answers
3361
Questions
Helped
1029792
Points
10654
First,with a volt meter,verify 220 volts at the terminal block where the cord attaches to the dryer. Look for a burned or broken wire here also.
On the face of the heater canister are 2 relays. Part #3700135 is a thermal fuse. part #37001133 is a thermostat limit switch. With a volt meter set for ohms or continuity read these 2 relays. If you get no reading replace them. It may be just the thermal fuse that reads bad. Replace both if either one reads bad.
If these relays are bad,you also want to check and clear the exhaust vent of lint or blockage.
Frigidaire Model FEQB2152FE1. Start dryer and after 5 minutes "Ad" code; lights blink dryer drum turns, but does not dry clothes
Check that exhaust air vent is venting air. If not, clear vent and retry.
Check that heating element is heating. if not, check overheat switch for continuity with power unplugged. If you don't have continuity get new switch. If it reads ontinuity then suspect the heating element.
Roper model res6745pqo ser.ms4808124 dryer Dryer works except no heat
You have a bad heater element, or high limit/thermostat. Check your vent for restrictions also. A restricted vent will cause higher heat and thus reduce lifetime on these componants. Rich
2answers
My dryer doesn't heat anymore, the drum rotates when you push the on button, and my switch box is fine , none of the switches have tripped. Usually the dryer sensor signals when the clothes are dry and the...
Heating element thermal cut-off (thermal fuse) 360 degrees and high-limit thermostat 250 degrees. Its about $20.00 ,test for continuity with a multimeter,if bad unit will not heat,i have had to replace mine twice already,also make sure your vent is not kinked or blocked,this part is located on the side of the heating element housing!
Dec 31, 2009 • Dryers
Maytag dryer is not heat up. I think the heating
Hello, There are a couple of variations of the heating element, depending on the series number of your dryer.
Here's a link to the parts list and line drawing so you can verify the proper element you need.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=SDE4606AYW&productCategoryId=0151200&brandId=3048&modelName=MAYTAG-LAUNDRY&diagramPageId=00005&componentDescription=REAR%20BLKHD,%20AIR%20DUCT,%20ROLLER&HTR%20(ELE)&documentId=M0510059&blt=06
If you have a Series 14 dryer, the element part number is #37001134, otherwise, there are a couple of other elements that your particular dryer might use, so check the model number and product tag so you can get the right parts.
You might want to check the element first, to make sure it is defective, before you order replacement parts, as it might be a faulty thermal fuse, which is much less expensive to replace than the heating element.
If you have a multimeter, you can check the fuse to see if it's failed. Be sure to turn the power off and unplug the dryer before removing the back access panel and checking the thermal fuse (see drawing in link above)
With the meter set to measure resisitance (Ohms) you can put a test lead on each side of the thermal fuse and if you get a reading showing no continuitity, then the thermal fuse is blown and needs to be replaced.
You can also check the heating element using the same method, again, make sure the dryer is unplugged before testing the continuity of the heating element, if you don't get a continuity reading, then the heating element is bad too.
I hope you find this Very Helpful and best regards!
1helpful
Won't start or heat up
Check your breaker box for fuse box. sounds like you are only getting 1 leg of the 220VAC to the machine.
Maytag Atlantis electric dryer Model
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Aug 08, 2009 • Dryers
No heat from dryer
You have a bad heating element and or a bad high limit switch. Check them for continuity with a volt meter. No continuity, replace the part.
1helpful
Heating element is getting red hot - like a heater.
No the first thing I would check is the vent going outside may be cloged the air going across the heating element should keep it from glowing real bright
2helpful
2answers
REPLACE HEATING ELEMENT
This really depends on what make your Dryer is can you post the make or model?
Dec 21, 2007 • Dryers
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
