Question about Apple iPhone Smartphone
IPhone sync with Outlook Calendar - Appointment time put on iPhone 1 hr later.
When I sync my iPhone with a Outlook Calendar the appointmens originating from Outlook showup on my iPhone as an hr later than what it was on Outlook. The appointmens originating from my iphone show on Outlook as an hr earlier that what was on my iPhone. The time on both my computer an iPhone are the same.
E.g. - Outlook appointment 2:00 p.m. After syncing with iPhone the same appointment on my iPhone is shows as 3:00. (Stays the same on Outlook)
  • 1 more comment
  • dmjpierce
    dmjpierce Dec 14, 2007
    Thanks for the solution. I had actually tried changing the time zone but apparently I saved or selected the wrong one on my iPhone. Now all is good. Thanks!
  • mloyd Nov 21, 2008
    . The issue I'm having is that my appointments on my iPhone are posted one hour later than they should be as compared to MS Outlook Calendar. For example, I'll have an appointment scheduled for 3:00 PM EST in Outlook, but that shows as 4:00 PM EST on my iPhone. I've triple-checked all of my time zone settings and everything, on both my laptop and my phone, are configured for EST, so I don’t think that is the problem. I'm wondering if there's some configuration in Outlook that I'm overlooking. Oddly, I didn’t have this problem when I first got the phone a few weeks ago. Unfortunately, I don’t know what may have triggered this. It is possible it may have been the first time I cable-synched my phone, but I really can’t recall.
  • nsbradfield Jan 12, 2009
    I have tried the solution of matching my time zone on my iPhone and iCal to Eastern, but the iPhone still changes the time of my events to Central. If I create an event on the iPhone, there are no problems. If I create the event in iCal, the iPhone changes it.
    New Friend:
This solution pertains only to the one hour time difference people notice upon syncing to MS outlook.
In iPhone, there are two areas where you have an option to change your time settings.
1. When you go to 'settings', then to 'general', you can set up time and date, and also 12-24 hour format. Please note that changing the time here DOES NOT correct the problem, despite iPhone displaying correct date, time and time zone. Many people in this thread have stated that the problem persisted despite them setting appropriate time zone.
2. When you go to 'settings', then to 'mail, contacts and calendars' row (NOT the 'General' row) - you get an option to change your time zone at the very bottom of all the choices. You will see that wrong time zone is selected here - likely cause of the problem. Correct this choice and the one hour discrepancy between appointments in outlook and iPhone disappears.
Additional problem solutions - in the solution No. 2, if you set 'Time Zome Support' to 'ON', then all your appointments in the calendar will be displayed in the time zone of your HOME address. In other words, for example, if you are a person in central time zone, your appointments will be displayed ALWAYS in central time zone format - they will NOT change automatically when you travel from central time zone to eastern time zone. On the other hand, if you set the time zone support to 'OFF', then all your outlook appointment display times will change and adjust according to any time zone you travel to - This is often an inconvenience since most of us would like to remember our appointments as they were made in our home time zone, regardless of what time zone we traveled to.
Please note that the above solution pertains to only display of appoint times in outlook - This solution does NOT relate to the time displayed by iPhone and how that displayed time adjusts when you travel to different time zone away from your home time zone. This second issue is addressed below -
You can get your iPhone to display the current time in two ways -
1. Either always show the time in your home time zone, regardless of where you are (i.e., a person from Texas central time zone can set up to see the time always in central time, even if he/she travels to another time zone). This display setup is good for people who always think of time in their home time zone and then do mental conversions to reach at the local time zone time.
2. On the other hand, you can get iPhone to do this for you and change displayed clock time automatically to the local time zone that you have traveled to, away from your home time zone. Please note that enabling this capability in iPhone has no bearing on how the appointments are displayed in MS outlook.
Go to 'Settings'. Go to 'General' tab. then click on 'date and time'. Pick the 'set automatically' option to 'ON'. Now, the iPhone will automatically adjust displayed time to show the current time in which ever time zone you travel to.
If you set the 'set automatically' option to 'OFF', then you can select your home time zone. Then, the iPhone will always display time in your home city time zone and will NOT change even if you travel to a different time zone.
So, in summary, there are two places you need to adjust the time zones in iPhone - to do two separate tasks, first task of displaying appointments always in your home time zone upon syncing with outlook thereby avoiding the one hour skip; Second task of getting iPhone to display either your home time zone clock, or getting it to adjust current time to reflect the time in new time zone you travel to.
Hope this helps.
Posted on Jun 06, 2010
  • kamayogi Jun 06, 2010
    Please see my earlier post titled solution n#6 above.
    Thanks.
I had the same problem. My company outlook server is in the US but I am based in the UK. Simple solution though. Just turn the Time Zone Support off. Settings-Time&Date-Time Zone Support off. It will automatically update your calendar and change all times to be your local times.
Hope this helps :-)
Posted on Feb 29, 2008
This feature like most business features simply does not work consistently or correctly on the iPhone. The fix is to user Blackberry or some other business class smartphone for another year or so until Apple provides a phone that is up to the task of business apps.
Posted on Jan 26, 2010
    New Friend:
Hi
I tried all of the above mentioned solutions none worked. When i sync with i phone, on my i phone appointment was showing one hour earlier than on my computer. So my solution is go to Calendar options-change time zones in your Outlook and set the time zone(original time zone) to offset difference between your computer and i phone. Don't change the windows time. So i set the time zone +1 hour compared to my computer time. When i synced it worked.
I hope it will work for you too.
Posted on Mar 25, 2010
    Habit-Forming:
    New Friend:
  • 27 Answers
World time World Time Clock
Posted on Feb 16, 2017
I found a solution! Try this:
1. On your iPhone, choose Settings
2. Choose General
3. Choose Date & Time
4. Turn the Time Zone Support "Off"
It worked for me!
Posted on May 06, 2008
This is clasic when syncing with devices... the problem is that you have diferent time zones between devices. Set the iPhone time zone to match the one of the PC. That will work.
Posted on Dec 14, 2007
    New Friend:
I tried what's mentioned with the above and nothing changed can anybody help !!!
Posted on Mar 09, 2010
With the Iphone 2.0 or the 3G you can fix the time zones by:
1. Go to Settings
2. Go to Mail, Contacts, Calendars
3. Scroll down to Claendar- Time Zone Support
4. Change the time zone
Posted on Jul 26, 2008
SOURCE:
Syncing my iPhone 5s with outlook 2007 and vise versa
Go to the Microsoft support site the instruction are there.
Jun 01, 2016 | Cell Phones
When I sync the outlook calendar to my iphone, one of two things happens. 1. If I put an all day event in outlook, it syncs to the iphone a day earlier (both otlook & iphone are on same date &...
Make sure time-zone is the same for both iPhone and the computer.
On iPhone setting > Mail,Contacts,Calendars setting > Time Zone Support, make sure you are choosing the city where you are in.
Otherwise, make sure you have updated the iTunes to 7.5 or later.
Update to iTunes 7.5 or later to resolve this issue. If you're not able to update, continue reading for other options to resolve the issue.
Each Outlook calendar event has an internal property known as "Message Class." When some Outlook plug-ins are installed (such as Live Search Maps), the setting for the Message Class property can change from its default of "IPM.Appointment" to something else. iPhone and iPod touch are only able sync calendar events with the Message Class set to "IPM.Appointment," therefore any calendar events created after installing certain Outlook plugins may no longer sync.
To verify this, examine the property of the Calendar event items for MS Outlook and see if the Message Class shows something other than "IPM.Appointment" in any of the calendar events. To view the Message Class property for your Outlook Calendar events, add the Message Class field as one of the columns in the Current View using these steps:
  1. Open Outlook Calendar on the computer.
  2. Choose View > Current View > Events.
  3. For Windows Vista, choose View > Current View > Customize Current View.
    For Windows XP, choose View > Arrange By > Current View > Customize Current View.
  4. Click the Fields button and choose All Appointment fields from the pop-up menu in the "Select available fields from" section.
  5. In the "Available Fields" column, select "Message Class" and click the Add button.
  6. Click OK.
  7. Click OK.
Now verify that all your calendar events are showing "IPM.Appointment" for the Message Class column. If you have calendar events showing a different value other than "IPM.Appointment" you will need to perform the following steps to fix the issue.
  1. Uninstall any Outlook plugins such as Live Search Maps or other plugins which change the default Message Class "IPM.Appointment" to some other value. Once the plugins have been removed, verify if those calendar events revert back to the Message Class of "IPM.Appointment" so that you can sync the calendar data to iPhone/iPod touch. If you are able to sync, try adding the plugins back one at a time and verify that you are still able to sync.
  2. If removing the Outlook plugins does not change the Message Class value for the calendar events, manually change the Message Class value of those calendar events to "IPM.Appointment." For more information on Message Class and how to change the Message Class fields/value, refer to Microsoft's KB article 201087 How to update existing items in an Outlook folder to use a new custom form
Apr 06, 2010 | Apple iPhone Smartphone
Outlook changes appt times when synced with iPhone.
i have pinnacle dv500
my problem dv 500 not install driver
driver error e4 overllay plz help me
Sep 04, 2009 | Apple iPhone 3G
Downloading calendar from palm to iphone
In order to get your calendar from Palm to iPhone, you first need to sync your contact from Palm to Windows Outlook and then select the option "sync calendar from Outlook" in iTunes, once selected all your details would be in sync.
Jul 01, 2009 | Apple iPhone Smartphone
When sync outlook to verizon Q phone
1. Create a new calendar item in Outlook/Exchange.
2. Sync
3. Update the calendar time on the handheld device.
4. The device is overwritten by Outlook/Exchange upon next sync as a
'conflict'
So, the new time of my appointment (valid and important) is not only never
updated in Outlook (I could almost live with this) but it is changed BACK to
the original time
Feb 28, 2009 | Microsoft Office Outlook 2003 for PC
Appts on iPhone do not synch to computer
you need to set your preferences in itunes to sync properly
Nov 17, 2008 | Apple iPhone Smartphone
Sync iphone calendar with outlook 2003
hello!
try the ff:
Reset Sync History
- Open iTunes
- On the Edit menu, click Preferences.
- Click the Syncing tab.
- Click the Reset Sync History button.
disable third-party add-ins
- Open Outlook 2003
- From the Tools menu, choose Options.
- Click the Other tab.
- Click the Advanced Options button.
- Click the COM Add-Ins button.
- Determine whether any third-party (non-Apple) add-ins are present in this list. The add-in "iTunes Outlook add-in" is made by Apple and can be left alone.
- Deselect the checkbox for each third-party add-in in this list.
- Click OK.
Reinstall the iTunes software
Attempt to sync content in a new Windows user
- From the Start menu, choose Control Panel.
- Open User Accounts.
- Select Create a new account and follow the instructions to complete the account setup process.
Note: Make sure you only use standard ASCII characters for the new user name.
- Once the new account is created, choose Log Off from the Start menu.
- Log into the newly created user account.
Once you are logged into the new user account, create a few test contacts and/or calendar events in your compatible application of choice and attempt to sync that data to your iPhone.
May 08, 2008 | Apple iPhone Smartphone
Sync Outlook 2000
You can transfer your contact list, but not your calender. Here are the steps to take to successfully transfer your contact list from outlook 2000 to the iPhone:
1. In Outlook, export your contact list as a Comma Separated Values (Windows) file
2. In windows accessories, launch Address Book
3. Import into Windows Address Book the file you created in step one
4. Now back in iTunes, sync your iPhone contact list with Windows Address Book
You contacts should come over intact.
Sorry, but there is no solution that I know of to import Calendar events.
JAF
Oct 19, 2007 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
23,229 people viewed this question
Top Apple Cell Phones Experts
Ekse
jacobcheatha
Level 1 Expert
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
