Radio Communications Logo
Sheilah Czarniak Posted on Oct 03, 2019
Squelch wont stop bc350a - Radio Communications
Kristyanna Virgona
Level 1:
New Friend:
  • Contributor 28 Answers
  • Posted on Oct 03, 2019
Kristyanna Virgona
Contributor
Level 1:
New Friend:
Answers
28
Questions
Helped
7130
Points
52
You may have a bad squelch pot on the radio. try turning it fully in one direction an back in the other direction. it also could be that the Pot is dirty get some contact cleaner and open up the radio and squirt a very little cleaner into the open spot of the Pot. then rotate the know several times. if you do not have something like CRC QD Contact Cleaner you can get it in a good hardwood store like ACE or TrueValue, and even Home Depot. you can use only 91-99% Electronic Grade Isopropyl Alcohol, do not use the 70% Isopropyl Alcohol.
1 Related Answer
fishdoctorfi
Shannon Currie
  • 178 Answers
  • Posted on Dec 22, 2009
SOURCE: where can I buy a squelch for my Uniden BC350a
You will be better of to send it back and let the factory do it...I had the same with a scanner and it drove me crazy.....sorry. [If you have to try/Radio shak]
Uniden Bearcat BC350A Scanner. How do I get the memory loss off it.
Question edited to add FULL make model (what it is) as needed on Fixya.
Memory Loss. - Uniden BC350A Support Question - HelpOwl ...
https://www.helpowl.com > BC350A > Technical-Support
Feb. 29, 2016 - Memory loss occurs if the the scanner is left for a long period of time without power. Please note that in case of memory loss to the scanner ...
BC350A Memory Loss - Uniden - HelpOwl.com
https://www.helpowl.com > Uniden > BC350A > Research
Our system has returned the following pages from the Uniden BC350A data we have on file. ... Avoid a location that could cause scanner memory loss.
Helpful Hints - Uniden BC350A User Manual - ManualsLib
https://www.manualslib.com > ... > User manual
memory loss. If memory is lost, simply reprogram each channel. The display shows "MEMO LOSS" when memory is lost. Always press each keypad button firmly ...
Squelch is open all the time on uniden bc350a scanner
Have you turned the squelch knob all the way in both directions, to see if that helps?
If so, then you have to replace that squelch knob unit, with a newbie.
I hope this helps.
Cheers,
Peter
1helpful
I have a BC350A. It cuts in and out, and won't broadcast instantly, like when new. Powers up ok and will eventually play ok. tried several diff. locations in the house-no help. tried a second ant. -no...
Try cleaning the knob, it may have dirt in the Volume,Squelch. Spray Tuner cleaner inside knobs (After removing knobs off top, may have to take off cover to do this) Make sure unplugged when cleaning it. Make sure speaker wires soldered good. Change speaker to new one --if possible. Get a outdoor antenna with a Booster for scanners. Try to see if antennuator is on radio..It may be switch that says 0db--10db selector. make sure its on 0db for indoor types...10 db for outdoors. Adjust sqelch until it stops hiss--keep it 2 notches above hiss for weak signals.
My uniden bc350a police scanner is not scanning frequencies stops on one and stays
Press manual,adjust the squelch to where it is silent,press scan. hope this helps..
Where can I buy a squelch for my Uniden BC350a scanner
1helpful
2answers
Won't stop scanning
L16 Disc coil needs adjustment, Audio is slightly off, and improper noise to DC squelch level detect used to stop scan on active channel. Set to an on freq signal like a NOAA weather channel, and useing a non-metallic tool, adjust to best sounding audio, probably less than a half turn either direction. An on freq signal moduated by 1000hertz, connect scope to speaker and adjust for highest undistorted recovered audio would be better if you could.
Top Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Radio Communication Expert? Answer questions, earn points and help others
