Question about Boating
My 2007 Avalon pontoon boat stalls out I have two lights next to key green and red red light comes on and alarm goes off then stalls out
    New Friend:
    Problem Solver:
  • 12 Answers
Not knowing the engine manufacturer and horsepower it is still one of two items. Most of today's engines have an automatic oil feed if it is a two-stroke engine. The four-strokes have something similar, except it deals with maintaining a constant oil pressure for the engine and recognizes a low oil condition as well. Another potential issue is a restricted fuel supply going to the engine. Larger engines obviously, require more fuel. An air leak into the fuel line or a fuel restriction between the fuel tank and the engine can also cause alarms to activate.
Posted on Oct 06, 2019
6ya staff
SOURCE:
Anonymous
SOURCE: I need a new inflation valve for my colorado pontoon boat
Check E-bay -
Item number: 310151809453, Pontoon Boat Boats Outdoor Parts Repair Kit Kits black
What is your problems with pontoon bladder
Thanks for reply
Posted on Jul 09, 2009
DD1992
Dylon
  • 122 Answers
go to canadian tire or walmart
Posted on Aug 23, 2009
Anonymous
SOURCE: battery operated key and car alarm Porsche 911
change battery
Posted on Dec 19, 2009
Jose Garcia
  • 453 Answers
SOURCE: Blinking red light and tv will not turn on.
problem on power supply , u may have 2 bAD capacitor
Posted on Apr 14, 2010
emissionwiz
Marvin
  • 85206 Answers
SOURCE: 2006 AVALON KEY IGNITION RED LIGHT FLASHING
Is this a new problem? I think it may be normal.
Posted on Jun 22, 2012
How do you know if a fuse is blown in your pontoon tracker boat
On the engine itself is a series of fuses , pull them out one at a time and look. But a fuse shouldn't cause the alarm to go . Blown fuse means no power , no power means no alarm. Never heard of an ignite alarm might that be a gas vapour alarm ... find out where the sensor is
May 26, 2018 | Boating
2006 Jeep Liberty - While pulling boat the check engine light comes on and it begins to sputter and stall. After I remove the boat and drive it, the light goes off and no more sputter and stalling?
The check engine light will come on when the management computer detects a fault that can affect exhaust emissions. When that happens the computer switches to a get you home programme and records a fault code.
A code read is required to discover the fault which should then be verified by independent tests before wasting money chasing down blind alleys.
Mar 26, 2018 | Jeep Cars & Trucks
2011 nissan sentra s door lock actuator wiring diagram
From the plug in door lock harness of the Viper alarm (green and blue): the green lock wire goes to the red wire of the vehicle in the driver kick panel and the blue wire goes to the pink wire in the kick panel. The light green with black wire from the Viper alarm goes to the white wire in the drivers kick panel. This white wire is the factory alarm disarm wire. It tests with the key in the door cylinder. Turn the key to unlock the door and the wire should register ground.
Aug 01, 2012 | Viper Vehicle Parts & Accessories
2000 Toyota Avalon stalls when foot is not on gas pedal. Any ideas. I put it neutral at red lights and pop back into drive when light turns green.
Sounds like the IAC valve is carboned up. This valve can usually be removed easily with 1 connector and 2 bolts. It is how the engine controls the idle speed. Many times a can of carb cleaner and working the piston back and forth on it will free it up for many more miles.
Turn on the a/c at idle. does the idle speed change?
May 02, 2010 | 2000 Toyota Avalon
I have a 1998 Champion 181 bass boat. The navigation lights are not working properly. - When I plug in the front green/red light, it immediately comes on with control switches in the OFF position. (The...
Check the switch. It sounds like it has seen better days. Also check the wires on the back of the switch to see if they are shorting out. The problem is at the switch area. Good luck.
Apr 15, 2009 | RTO Oar Sockets
How to trun off Maintenance required light in 2006 Toyota Avalon
turn ignition key to 'acc' or 'lock' position press and hold tripmeter knob while pressing knob turn key to 'on' but do not turn over engine release trip when light goes out
Mar 19, 2009 | 2007 Toyota Avalon
Boating Logo
48 people viewed this question
Top Boating Experts
ray gallant
ray gallant
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Boating Expert? Answer questions, earn points and help others
