Question about Golf
My powaglide single seat golf buggy has full power to the batteries, it worked yesterday but now only powers on but will not move, any ideas what is wrong
6ya staff
SOURCE:
Anonymous
SOURCE: 2000 blazer power seat
The guy that posted the first solution...that works...My power seat module went bad , so I used a 12 volt batery charger on the wires to move my power seats.
Posted on Mar 21, 2009
robert bishop
  • 135 Answers
SOURCE: lost power to the driver seat and heat for both front seats
CHECK FUSES AND LOOK UNDER SEAT FOR A PLUGS IN WIRE, ALOT OF MODELS HAVE THE POWER PLUG UNDER THE SEAT, TRY THAT ,ROBERT
Posted on Jun 16, 2009
Anonymous
  • 10 Answers
SOURCE: power seat issue
Get out your voltmeter, unplug the connection to the seat's motor, underneath the seat, and hit the switch. if youve got power going to the motor then youll need to replace the motor. If not, it's probably the switch. Also make sure the wires are not cut or damaged somewhere between the switch and the seat.
Posted on Jun 20, 2009
kirtec auto
  • 1348 Answers
SOURCE: power windows, sunroof, seats and door locks do not work
that is the interior lights and alarm,remote module
Posted on Jul 18, 2009
egstriker23
Mitchell Cathey
  • 44 Answers
SOURCE: pt cruiser seat adjuster problems
You might have a problem with the wiring under the seat. The best thing to do is to reach under the seat and move some of the wires away from the track that the seat moves along. Most likely there is a short to ground because the wires are rubbing against the seat track as it is moved back and forth. You need to grab a flashlight and look under the seat for wires touching the seat tracks. When you find them, you can most likely use some electrical tape to wrap the exposed wires and keep those wires from touching each other and that area from touching the seat track. Make sure you route the wires away from the seat track tight enough to the seat's underside, but loose enough to allow the wires to move with the seat as it travels the full length of its track. The fuse for the seat has probably blown so you would need to replace the power seat fuse AFTER you wrap and reroute the wires to prevent blowing the new fuse.
Hope this helps!
Posted on Sep 07, 2010
My golf buggy is breaking down about 17 holes into a round the batteries are 2yr old have put on metre And each battery shows 8.2 or 8.4 so i am baffled why it should run out of power.
Fully charge the buggy. I know I'm going back to basics here.
Try removing or disconnecting the batteries **one at a time**. Give the terminals and clamps a really good clean. Possibly give them a LIGHT rub with FINE sandpaper. I find a suede shoe brush works well for this job.
Once each battery is isolated test it's voltage. An 8 volt battery should read a strong 8.4 volts when fully charged.
Depending on how much use the buggy gets, batteries do get old and drop in performance. If you're still unsure get a good battery specialist to assess each one.
Apr 30, 2018 | Cars & Trucks
The front seats for our 2003 Escalade will not move forward or backward and the heat control for the front seats will not work.
Does your Escalade have memory seats ?
There are 2 options of power seat systems available in full size trucks. The 6 way driver and passenger power seats, and 8 way driver and passenger power seats with driver memory. For the driver memory seat operation refer to Memory Seats Description and Operation . Power seats without memory are completely controlled through the power seat switch. Battery voltage is supplied to the power seat switch through the power seat circuit breaker. While the seat adjuster switches are in an inactive state the switch contacts are closed to the power seat switch ground circuit. When a power seat switch is pressed to an active state the switch contact is closed to the battery voltage supply circuit. Each seat adjuster motor is controlled by the power seat switch through 2 motor control circuits. The seat adjuster motors are bidirectional and the direction of adjuster motor rotation is determined by which of the adjuster motor control circuits is switched to battery voltage while the other remains grounded.
Jan 16, 2017 | 2003 Cadillac Escalade
Driver side electric seat is stuck in the far forward position and won't move. How do I move it manually or fix the motor.
Auto Repair: How to Replace a Power Seat Motor - YouTube
? 1:44
https://www.youtube.com/watch?v=EDh-0rs5Fjo
Oct 26, 2010 - Uploaded by automdvideos
Auto Repair: How to Replace a Power Seat Motor ... 2007 - 2008 Ford Expedition/Lincoln Navigator Driver Bottom Install Video ...2003-2006 Chevy/GMC Seat Cover Install 1 of 3 - eBay Ready ...2000 Ford Explorer Front Seat Track Stuck Motor Repair - Duration: 4:39. by cubmancan 4,959 views. 4:39.
Drivers seat is dead! No power seat or heat. - TheDieselGarage.comwww.thedieselgarage.com/.../96465-drivers-seat-dead-no-power-seat-hea...Mar 22, 2010 - 2003-2005 Chevrolet Avalanche, Silverado, Suburban, Tahoe 2003-2005.... Power seat on driver side didn't work.....passenger did! Neither ...DANG electric seat ' Chevy Truck Forum ' GM Truck Clubwww.gmtruckclub.com/forum/threads/dang-electric-seat.2990/Apr 27, 2006 - 10 posts - ‎7 authors'03 Tahoe My driver seat just stopped, of corse not where I need it, the ... I have a 2003Tahoe and both heated seats are not working. ... with my seat heater on the drivers seat in my 03 Avalanche, it turns ... The driver's side on my Silverado gets way warmer than the passenger side. ... Frozen New Member.Power Seat Problems?? - Tahoe Forum - Che
Dec 29, 2015 | 2003 Chevrolet Avalanche
I have an 05 reg golf with elec power steering, every thing was ok untill i changed o/s front tyre, as soon as i went to move the car after letting the jack down there was no power steering, any ideas?
Check the wiring harness connector to make sure you didn't knock it off. Also, you can try disconnecting your battery for a few minutes to see if it will reset itself.
I hope this helps.
Jul 18, 2011 | 2005 Volkswagen Golf
Pt cruiser seat adjuster problems - my drivers seat power seat adjuster doesn't work (as of yesterday ) and it is stuck in the fully forward position - it there anything i can do? it would only move up...
Hope this helps!
Sep 06, 2010 | Chrysler PT Cruiser Cars & Trucks
My 1983 ez go golf cart will not run with a load on it what do i need to do to fix it?
Check batteries for proper voltage under load. If this does not solver the problem, email me at rrgolfcart@bellsouth.net
Aug 30, 2009 | 1995 Volkswagen Golf
Power windows, sunroof, seats and door locks do not work
Jul 18, 2009 | 2004 Nissan Maxima
Golf Logo
54 people viewed this question
Top Golf Experts
FastHarley
FastHarley
ray gallant
ray gallant
Kardoc
Are you a Golf Expert? Answer questions, earn points and help others
