A typical answer for this is to initially unplug the water warmer from its electrical stockpile. Next, evacuate the spread by unscrewing the four fastens that hold it place. The indoor mounted 45HI models have a strip link interfacing the showcase to the PC board. It would be ideal if you be cautious as to not harm this wire. You should disengage it utilizing the dark connector found 6 crawls from the showcase itself.
Once inside the water radiator, you will see the PC board situated on the left-hand side, at the base corner of your warmer. Next, expel the two screws on the essence of the PC board at the base. Next, detach and reconnect the majority of the wires each in turn, which is associated with the PC board to confirm that everything is situated appropriately. You would then be able to sink the PC board back spot, supplant the spread, plug up the power supply, and endeavor to run the water radiator as typical.
For More Information You Can Visit https://www.indiapropertyclinic.com/services/water-heater-install-repair
