SOURCE: How can I adjust linkage on my 2015 zero turn husqvarna mower
If you follow the control arms down to the Hydrostatic hydraulic pumps on either side with should be a bolt that will adjust the forward and reverse aligning of the arms. if you are adjusting the speed of either side, there should be a flow adjustment screw on the pumps as well. Usually backing the screw out will slow the movement of one wheel and adjusting the screw in will speed the movement up of one wheel. Each wheel is done individually.
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
Bent blade(s) or other obstruction lodged in deck<?>.
