AEG Electrolux lavamat 62810 made in germany
SOURCE: need the manual for Aeg oko lavamat 74630
Dear Biyo,
Please download the manual from here. (simply press left click)
http://www.manualshark.org/manualshark/files/5/pdf_10516.pdf
I have sent you an email as well.
Regards,
EngineerGR
SOURCE: E60 Error Code on converted 60Hz outlet
E60- Fault in washing NTC sensor
-Washing NTC sensor, wiring, main PCB
Unplug your washer for 1 hour and then plug it back.See if this reset helps.
SOURCE: aeg electrolux lavamat 74820 e91 fault
Hope this helps .
Shane
Testimonial: "thanks we need a repairman to do this thanks anyway"
SOURCE: AEG Oko-Lavamat 86820 Update Error code C9
Hello. I got error code C9 on a LAVAMAT 86800. It pumped in water, and it pumps out water. You can select pump in or out....But the motor dont turn. It will not sentrifuge. So I bought new carbon brush'es on the net. One of them were totally wore down. Now it works. They lasted for 10 years.
SOURCE: Repair to hole in washer plastic drum.
I had the same issue, I got some liquied fiberglass from out local car shop, striped down the washer and split the drum so I could get the the inside and out, I rubed down the hole with soem ruff sand paper to make a good key then applyed the fiberglass, waited for 3 hours to make sure it was good, put it backtogether and all is done been great now for last 3 years.
Colin
