It reads a design from memory but cards come up blank
Try other memory card on galaxy 2100. If other memory card read by Samsung galaxy then problem with memory card. Also check same memory card on other mobile. If memory card work fine on other mobile then problem with memory card.
http://mobile-cellphones.blogspot.com/2007/09/mobile-phones-tips-tricks.html
SOURCE: Unable to read original card
I called brother and I had set the hoop size to the wrong demension. I had it set for a 5X7 hoop and my machine uses a 4X4 hoop, It works fine now. Hope this helps you
SOURCE: problems with the memory card
HI Have you contacted either the dealer you bought the machine from or Janome directly? There is a Janome group on the internet at Yahoogroups...maybe someone there would have the answer? I've been told that the owner of Janome monitors the group--that is WOW for an international company to pay attention to the customers! Good luck,pat
SOURCE: memory card
You will need to buy a Compact Flash (CF) card (up to 128MB is a good size, NOT more than 256MB), a card reader to attach to the PC also a PCMCIA carrier/adapter for the CF card to be inserted into your sewing machine if the CF card will not go directly in.
SOURCE: Kenmore 19005
The memory card cannot be over 128 mb. Also the files need to be .jef format and stored in an emb folder on the card. I hope this helps.
SOURCE: Blank Card, PE Design says it's a ''read only''
Hi - I think the problem is that although the Magic Card is compatible with your machine, it is not recognized by with the PED writer. I have the Brother PED-Basic sfotware and a Brother PED-Basic USB card writer box. The only blank card that the my Brother reader can read is the blank cards made by Brother. Which embroidery machine do you have (not critical - I'm just curious).
If you have both a Magic card and Magic Box, the box should have it's own software. I don't think the PE Design software recognizes non-brother equipment (bummer). The link I've provided below is to a dealer that sells two different blank Brother Cards. One of the cards is 1 mb. The other is 4 mb. They are the same price. You might check your documentation to see whether both cards are compatible with your reader and software. If you're not sure, you can call the dealer directly and ask. I have dealt with this dealer many times and find that they have great prices and are very knowledgeable. This link should take you to the page on which the blank Brother Cards are displayed - scroll down if you don't see them right away.
http://webstore.quiltropolis.net/stores_app/Browse_dept_items.asp?Shopper_id=1617251646531617&Store_id=492&Page_id=17&categ_id=42&parent_ids=0,20
This dealer is located on the East Coast, so you probably won't be able to reach them by phone until tomorrow. I don't know of a dealer on the West Coast to whom I can refer you. One more thought - Babylock equipment is often interchangeable with Brother equipment. If you have a Babylock dealer in your area, you might be able to find a blank Babylock card that you can buy off the shelf. Just make sure you can return it just in case it won't work.
Let me know if I understand your situation correctly - if not, send me another comment and I'll be happy to research further. BTW - if it turns out that you can't use the Magic card and can't return it, you can probably sell it online.
Thanks for getting back - I really love doing this. If you have general questions about embroidery, feel free to ask. I own several consumer embroidery machines, and I operated a commerical embroidery business for several years.
Ginny
