Question about Bosch Washing Machines
What is a SOAKING AGENT mentioned in the manual for Bosch washing machine. Is SOAKING AGENT same as detergent? So do you put some detergent in that receptacle, and some more detergent in the left receptacle? I have a Bosch Axxis ELF 2050. I just put the detergent in the left receptacle, with a warm water setting. Not even lightest stain is removed!! Am I supposed to add A SOAKING AGENT too? And what on earth is that? I miss my Maytag! Simple and great!
SOURCE:
localwonder
  • 6784 Answers
SOURCE: My Bosch Axxis WFL pump drain blocked. I had a
Hi there, i have prepared two links. The first one is the original manual you requested and the second link refers to the quick reference guide.
Click here for the first link to your original manual.
Click here for the quick reference guide.
Posted on Feb 25, 2009
Dissolu
  • 221 Answers
SOURCE: Bosch Classixx6 washing machine. Which side for detergent?
Left one.
Posted on May 12, 2009
SOURCE: Bosch Axxis Washer Detergent slot codes; what do they mean?
soap goes in far left
softner middle
liquid all fabric bleach or powder bleach in far right
Posted on Jun 24, 2009
SOURCE: My Washing machine stains clothes;
I had the same problem, and it turns out that it is NOT the seal. It is the liquid fabric softener. The fabric softener dispenser needs to be cleaned periodically or it gets a black waxy, goopy, build up. It is this same buildup that ends up staining your clothes with dark brown or black stains. Just remove the dispenser and wash it our very well and the problem will be gone.
Posted on Apr 12, 2010
  • 662 Answers
SOURCE: BOSCH Maxx washing machine will drain and fill but
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Plug off the wall first. Remove the front lower panel, screws underneath. Be prepared for water, drain out from drain hose. Check filter for clogging, clean out. Sometimes when the load is unbalanced & the machine cannot adjust the load it stops. To avoid this make sure your wash is mixed with big and small clothes.
If this does not work remove the rear panel & check belt, should have half inch ‘give’. Still not good, remove belt, unscrew 2 bolts that hold the motor, unplug the motor connector, lever the motor back with a screwdriver. Check the motor brushes (at terminal end of motor), if they are any shorter than 1 cm replace brushes.
Try these sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
Pl click 'very helpful' for the free help, thnks.
Posted on Jun 16, 2010
Where do you pour bleach
The detergent dispenser draw where you put in the detergent has 3 sections.The compartment on the far right is for soaking agents. The compartment on the far left is for wash and stain removers (like bleach). The middle compartment is for fabric softeners, fabric conditioners.
Apr 10, 2012 | Bosch Axxis WFL 2060 Front Load Washer
There are 3 compartments . . .
It says the 1st compartment going left to right laundry detergant and stain remover, the middle is for the soaking agent, and the last one is for fabric softner. I hope that helps!
You can download the manual online and I found the info on page 12 of the manual.
Mar 02, 2010 | Bosch Axxis+ WFR 2460 Front Load Washer
I accidently put Jet Dry DISHWASHER CLEANER in my rinse agent dispenser and I need to know how to drain it out..help!
if you leave loading draw or lid open and do a hot wash with no detergent water will enter replacing the detergent you will have to do this several times till wash tub runs with clear water then refill with rinse agent.
Feb 16, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
We have a Bosch Classixx washing machine which infrequently stains quite badly items in the wash. Have made sure it is cleaned frequently
pull back door seal lip as far as it will go and you will find grey scum underneath this will stain your laundry during wash need to manually wipe out and put on 90 degree wash with biological detergent anything less wont touch it.
Nov 23, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Machine won't spin
When washing does the unit rotate in both directions ? If NO, the problem (likely) is the motor/brushes. If YES, insure you're not overloading or using non-HE detergent or more commonly refered to as "regular" detergent/soap. (soap is a very bad thing for these front load units).
Sep 20, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Cleaning agent placement
From left to right as you see.
1 This is for your frontloader soap powder or other detergent.
2 Fabric conditioner or softener. If this is too thick, mix with water to prevent clogging.
3 Detergent for soaking agent. I dont see 'bleach' anywhere
There is an panel, front bottom right which holds your pump filter, unscrew to clean out. But wait. Plug off the mains.
You will see a hose on the left, this is if your water in the tub cannot drain, you can drain it here. Your tub can hold upto 20 litres/4.4 gals.so have a suitable container to collect; carefully remove cap to drain out. Reason why it doesn't drain is because there is a block in your pump (right side) which you must clear.
To keep your pump from probs (a tip which you seldom see) empty all pockets of clothes before putting into machine. I have a non electronic Philco which i dont remember cleaning with hotwash or anything, 10years +
For exteriors do not use solvents or steel wool. Only hot soapy water with a mild non-abrasive cleaning agent, dry with soft towel.
Above should be useful. Pl rate.............
Mar 21, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Washing instructions
My book says for the Axxis WFL 2050/WFL 2060 : from the left while looking at it from the front: detergent for wash, stain remover, middle: fabric softener, fabric conditioner, right one: detergent for soaking agent. (Do not use chlorice bleach in this wasking machine).
Oct 11, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Front Load Washing Machine
Filling laundry detergent and/or additive
dispensers
Dispenser I: (RIGHT SIDE)
Dispenser II: (LEFT SIDE)
Detergent for wash, stain remover.
Dispenser 2: (MIDDLE)
Cleaning product, e.g. fabric softener, fabric
conditioner (do not fill above the lower edge of the
insert 1).
Dec 29, 2007 | Washing Machines
Detergent dispenser
As far as I am aware, there IS NO dispenser for bleach, you have to put bleach in drum before adding clothes and starting cycle. The far right compartment is only for "pre-wash" cycles, and if no pre-wash is selected, water will run through ALL compartments at the rinse stage..... Oshie
Feb 28, 2007 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washing Machines Logo
35 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
jimorris77
Dw Wooten
Dw Wooten
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
