Disconnected battery plugs and when plugged back in had no power
SOURCE: my pride IV scooter will not start I get a click
An 8-flash code indicates that the controller has shot craps. The controller is located under the shroud beneath the seat by the batteries and it controls all of the power and automatic functions of the scooter. They are damaged most often by water infiltration like running through deep puddles, etc. or by over-amping the scooter by driving it through unstable terrain like sand, mud, wet grass. There's no fix for it but a replacement and it's pricey...several hundred dollars.
SOURCE: Pride Legend scooter won't hold charge
check the wiring from the batteries as a wire could have come loose.
Regards
GeWiz
SOURCE: Pride celebrity XL won't go.
Have you checked the motor brushes for wear and spring tension, sometimes the spring becomes brittle and breaks but can sometimes still make contact.
Regards Steve.
SOURCE: My Pride Legend 3 wheel scooter will not go
Hi, sounds like the speed pot that is attachment to the throttle lever is worn and needs replacing, this is normally a 5K pot,
Regards
GeWiz.
SOURCE: I wanted to get a copy of a manual for the Pride
you can download from this site http://www.pridemobility.com/international/UK/ukownersmanuals.asp
plz rate me
Testimonial: "Brilliant and so fast. I am very pleased thank you so much. D."
