I would have thought that would fix it too. When you say boat, I think oxidation on the faceplate connectors. Get a can of deoxit from caig laboratories. Best contact cleaner ever. Not sure if that’ll fix it but worth a try. Also worth having a can on the shelf in the garage/workbench. I’ve repaired electronics for years and this is the first thing in my tool box
SOURCE: My Face Plate was stolen and the Raido isn't 6 Months old
It is available from Pioneer Electronics, but the price will prolly make you pass out.
Check it here;
http://parts.pioneerelectronics.com/part.asp?productNum=XXA7322
Best of Luck.
SOURCE: Demo mode Kenwood KDC-237
To turn off the demo you need to press the src button to put it in standby mode. Then press the menu button as if to change the settings and use the joystick to scroll right until you see demo, then turn it to off....
Do as above to allow you to enter AUX mode this will let you plug in your MP3 player to the input on the face and hear music through it ;)
hope this helps you
philzee
SOURCE: JVC CAR RADIO KD SC 601 FACE PLATE
hi you can down load your user guide from :
http://uk.jvc-service.net/public/document.cfm?prog=InstrBook.cfm&Model=KD-SC601
Mark
www.blueice-electronics.co.uk
SOURCE: My DAB radio wont tune in to a station, just displays ''tuning''
This is not a solution but a suggestion - My Dad has this Hi-Fi and also has the same problem, unfortunately his warranty ran out 6 months ago. So, because of this I opened the stereo up. Inside there is a little (4in by 3in approx) PCB at the bottom back of the Hi-Fi above the CD section. This PCB is the tuner board. On this board there is another board (hybrid) with a BGA (Ball Grid Array) chip. BGA's sometimes lose connections between the pads on the board and the contacts under and on the chip. I am away in Germany for a little while but in 3 weeks when I visit my Mum & Dad again I am going to take the tuner board out and take it to work where we have a special heat gun for lifting surface mount chips. I am going to flux and reheat the BGA chip to reflow the joints under the chip. I am a Senior Test Technician with PCB experience so I DO know what I am doing. I let you all know how it goes.
SOURCE: HI, my renault clio radio and clock display are dead
Hi All, the very same thing happened to me. Cold weather broke my radio and the display screen stayed on with the time and temperature but the radio wouldn't work. I rang Renault & they said I need to come in an get a new radio but I put it off. In the end the problem started affecting my battery and the car wouldn't start. But then when I jump started it, it also started the radio again perfectly. Problem solved!
Hope this helps. Good luck!
