When I try to tune the radio, it scans the bands and do everything but does not run any stations. I have noticed the stereo tuned light is never on but the mono light can be turned on. Help me please.
Hi Jose, do you have connected the card with the AM and FM antennas on your Sony HCD EC55?
If this is the case and you cannot tune in, you have problems in the tuning module
Find a specialized Sony technical service
I hope you can solve the problem
Regards Franco Dosil
Hola Jose, tienes conectado la ficha con las antenas de AM y FM en tu Sony HCD EC55?
Si es asi y no puedes sintonizar nada, tienes problemas en el modulo de sintonia
Busca un servicio tecnico especializado Sony
Espero puedas resolver el problema
Saludos Franco Dosil
https://www.manualslib.com/manual/510640/Sony-Mhc-Ec55.html
SOURCE: Won't tune any stations
To be honest, at that price buy another one. It's not worth fixing. Sorry
SOURCE: manual tuneing on the Sony S2210
you need to press and hold the seek button the it should beep (or not) then you should be able to serch through manualy,just don't hit the button to fast as it will turn the auto search back on?
hope this helps?
SOURCE: How do I manually tune a Ford Focus 6006 Radio
Press the Menu button. At some point it'll put an 'M' next to the station frequency. Then hit the seek up and down button.
