Short answer, yes. Longer answer, maybe maybe not. IF the Lithium Ion battery is fully charged when you install it, the bike should be able to keep it fully charged. Lithium Ion batteries do not tend to lose their charge rapidly just sitting there with nothing on. It takes a special charger to charge them to begin with. Colder days, you need to "wake up" the batter with a couple hits of the starter or turning the headlight on, automatic with the key on most bikes. They simply won't give full power until you "wake them up". I am assuming you are talking about a replacement motorcycle battery, not some random lithium battery in this case. One problem is the lithium is much more expensive than the lead acid battery, and if you let the voltage fall to even relatively high levels (sometimes as much as 11 volts) it can ruin the battery totally. Lead acid can be much more forgiving. Leave your key on with a lithium, you could kill it beyond recharging. Lead acid batteries this is not the case, and lead acid batteries can be refreshed with fresh acid, once a lithium is gone, it's gone, there's no saving it. I would rethink why you want a lithium battery. It does save weight and often size, but I see no real advantages over the standard battery in use.
SOURCE: It says it's charged the lithium ion battery but
I hate to say it but the battery is defective. You may be able to get a replacement from the manufacturer if you contact them.
SOURCE: I have 18 volt Porter
No they are two different types of battery on the inside but the electric charge they put out is the same.
SOURCE: 18 volt dewalt lithium ion battery charger stopped working for no reason....
This can happen if the battery is too dead for too long. Keep trying to make it work like you have maybe 20-30 times. Or you can leave the battery in for a few days and let the logic chip do it's job. It should start working in a day or two.
SOURCE: Will the P110 charger charge a lithium ion battery
No, the P110, 18V NiCad battery charger, will not charge a 18V lithium ion battery. You need one of the dual-chemistry chargers. If you have the Ryobi ONE+ batteries, you can get the P117 charger ($30) or a charger with an extra battery (P126) from a store like Home Depot. A 6 battery charger and a 12V in-car charger are also available.
I wish that I had better news for you.
(who has the Ryobi 12V drill and charger, a few of the 4V tools, and a number of the ONE+ 18V devices and chargers. The single chemistry battery charger is not used much any more.)
