SOURCE: Kitchenaid Selectra Range Fuse location?
unit does not have fuses , if the top works ok then you are getting 220 volts , you probly have a bad control
SOURCE: Kitchen Aid Superba...freezer shuts off..
sounds like your defrost drain is frozen or blocked its in the freezer side under the back panel beneath the evaprator
SOURCE: Kitchen Aid Refer: KSSC42FMS01: The freezer, doesn't go below 32
How long have you had this refrigerator and is this the first time this has happened? Your refrigerator has a control board and I believe the board is causing the refrigerator not to defrost every 8 hours. Let me know these questions and I will help you resolve this. Thanks, Sea Breeze
SOURCE: coil element on kitchen aid model ker1201 slow to
some of the coiled eyes have two coils(elements). one of the coils can burn into at any point around the element rendering it useless while the other can still work. when you lift the glass top you will see the elements are shaped like springs. the elements metal is very britlle.it is you have to replace the entire eye to fix it. the coil most likely had a very gap in the break and acted like a short making and breaking connection until the gap was too wide then nothing. easy fix. just replace the entire eye (power UNPLUGGED!!!) match the old wires with the new part as you take the old part off. I mark them even with a sharpie. it has 3 to 5 wires on that plug into the eye unit. estimated cost for the part online is about 40 to 65 bucks.
Hi
Error code F5-E3 indicates that there is an issue with the
door latch switch assembly; if the switch tests open then the door lock
assembly should be replaced. Hope this helps...please post back for further
assistance.
Daniel
