Ovens Logo
Eric Laskowitz Posted on Sep 30, 2019
I have a Frigidaire wall oven model fgew3065kfb. After I used the self clean function the oven will not go past 190 degrees. Any ideas. Thanks
Steve McQueen
Level 1:
Habit-Forming:
  • Contributor 24 Answers
  • Posted on Sep 24, 2020
Steve McQueen
Contributor
Level 1:
Habit-Forming:
Answers
24
Questions
0
Helped
4657
Points
41
If it has been awhile since the self clean function has been used grease from cooking can build up on the inner contacts of the oven control. This would either need to be replaced or taken apart and cleaned. The self clean function should either be used more frequently or not at all,
5 Related Answers
Anonymous
  • 413 Answers
  • Posted on Jun 10, 2008
SOURCE: jenn air oven stuck closed after attempt to activate self-cleaning
The lock motor may have failed. Most often, bending a coat hanger into a hook and sliding from the right side as you move the door to the right,will allow you to release the lock and open the door.
Anonymous
  • 594 Answers
  • Posted on Aug 18, 2008
SOURCE: self cleaning oven
here is the link where you can download the owners manual for your stove.
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Lassomption/318200919en.pdf
you may have to copy and paste this into your browser. and it may take it a min to load.
please do not forget to rate and comment about your experience today on fixya.
Anonymous
  • 725 Answers
  • Posted on Sep 28, 2008
SOURCE: DCS double wall oven model WOSD 230 totally dead during first self clean
let me know if you don't get the solution... thanks
Anonymous
  • 41 Answers
  • Posted on Nov 18, 2008
SOURCE: oven takes a long time to heat up
your ignitor could be going out. the ignitor has to get hot enough in order for the gas to turn on and heat your oven. if your ignitor is going out, sometimes it doesn't glow hot enough for the gas to turn on, or it could be that is takes longer than normal to get hot enough to turn the gas on. I would replace the ignitor and that should solve the problem. Joe
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Dec 09, 2008
SOURCE: Frigidaire oven overheating
I would say that the oven thermostat is malfunctioning, and you will probably need a new one fitting.
Make sure the sensor inside the oven has not become detached, as this will make a differance.
Plz leave feedback.
Ta.
No heat on convection or self clean
If you have been using the self clean feature, you have probably burned out or damaged the connections to the fan and the convection fan element or thermistor. NEVER EVER use the self clean feature.
https://www.partselect.ca/Models/CGEB27S7CS2/Sections/BODY/?ModelID=1073773&ModelNum=CGEB27S7CS2&mfgModelNum=&ManufactureID=4&Selected=OTRVH5GS&Position=1&mfg=Frigidaire&Type=Wall%20Oven&Mark=1
4 Reasons to Stop Using Self-Cleaning Oven Feature ...
https://fixappliances.ca > 4-reasons-stop-using-self-clea...
A self-cleaning oven is a feature on many modern ovens that burns off cooking spills and splatters with an extremely high temperature (932 F° or 500 C°) to ...
How Self Cleaning Ovens Work · ‎Major Parts Damage · ‎Family Safety
Why You should Never Run A Self Clean Oven Cycle & A ...
https://www.generalappliancesvc.com > why-you-shoul...
Jan 29, 2020 - With an inside temperature exceeding 500° C, and a flash point (the temperature at which items can self-combust without an ignition source) .....
How do I clean my Frigidaire electric oven, Model FEF352AWF?
See page 13 for specific instructions.
ShopYourWay FRIGIDAIRE Free Standing Electric ShopYourWay
As tedious as it may seem I suggest that cleaning the unit by hand is the preferred process. Most failures that I have experienced have occurred just after the clean cycle is completed. There is a lot of stress during self clean and critical components are stressed and are more likely to fail. On two occasions I have had a failure days before family dinners. Usually in preparation for family we had been cleaning the oven. Both the temperature sensor and heating element have failed.
With a free standing oven repairs are a lot easier than with a built in wall oven requiring saw horses to remove and set. In any case plan to clean long before company in the event a repair results.
Why You Should Almost Never Use Your Oven Self Cleaning Function
Replacing element in oven
Pull out the oven & unplug it. If element is screwed to the back wall of the inside of oven, you can remove the screws to detach the element or if not, there should be a metal protective plate at the rear of the oven to access the element screws/wiring. Replace with same.
1helpful
Accidentally hit clean button on a Frigidaire Gallery Oven. Hit Cancel button. Oven door won't open.
I appreciate your post, C Maury!
From my understanding your hit the clean button on your Frigidaire wall oven and now the door will not open. I would hold down the cancel button for at least ten seconds, this should unlock the door. If that does not help I would recommend disconnecting power from your wall oven by flipping the household circuit breaker for ten minutes. I hope this information was helpful to some degree. -Matt
1helpful
How to use Frigidaire self cleaning instructions lost manual
Good Afternoon friend, thanks for your inquiry!
To locate instructions regarding self-clean on your Frigidaire range I would need to have your model number. I have provided a link for you to use once you have your model number to locate any Use and Care Guides available on your current appliance. I hope this helps to some degree and if you need assistance please reach back out. -Matt
Why is my self cleaning oven not working. I put it on self clean three times and it did not work. It has worked in the past. The oven is about 5 years old.
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Frigidaire gas wall oven
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
3helpful
The self cleaning instructions for my Frigidaire Gallery Pro Series Model FEB798WCCH do not inform how long to set timer. Any instructions would be helpful as I've never operated a self cleaning oven...
Hello- The function is automatic when clean button is pushed. Oven will lock, and turn on at full power for about 90 mins. This 'feature' can, and usually does eventually burn out circuits in the control board. Techs call this the 'self-destruct' option, cheerfully promoted by the salesman. Avoid using 'self clean'!  Scrape and clean with light soap/water. Turn on to 450deg. for about 30 min. This is about half the temp. of a 900deg. 'clean' cycle and a lot less expensive in the long run. Please acknowledge this post if info is helpful- have more if needed.- Thanks- Ed
1helpful
Self-cleaning gas oven
Door lock motor has probably failed.....Self clean on many
ovens can be a self destruct mode. Door latch motors, sensor
probes and even the electronic controls can be destroyed by
this operation. On many freestanding stoves the lock motor is located in the right rear (looking from the front) with a long rod connected to the lock. remove the motor and unhook the rod from the motor cam. Sometimes bending a coat hangar into a hook and sliding from the right side into the lock you can unlock the door.
Top Frigidaire Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Kell Le
Level 1 Expert
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
