Computers & Internet Logo
A
Anonymous Posted on Sep 30, 2019
I have a hp laptop hp620 when click on icons this pops up not valid win32 application why
Larry Ng
Level 3:
Top Expert:
  • HP Master 14,585 Answers
  • Posted on Sep 30, 2019
Larry Ng
HP Master
Level 3:
Top Expert:
Answers
14585
Questions
0
Helped
3277253
Points
66542
The OS is corrupted do the HP F11 reload of OS.
it's in the manual on your PC hp.com "called recovery" chapter.
for sure.
5 Related Answers
Anonymous
  • Posted on Jan 10, 2008
SOURCE: d:\ application can not run in Win32 mode
To correct and solve this error, follow this steps:
1. Run Task Manager (Ctrl-Alt-Del or right click on Taskbar)
2. Stop wscript.exe process if available by highlighting the process name and clicking End Process.
3. Then terminate explorer.exe process.
4. In Task Manager, click on File -> New Task (Run…).
5. Type “cmd” (without quotes) into the Open text box and click OK.
6. Type the following command one by one followed by hitting Enter key:
del c:\autorun.* /f /s /q /a
del d:\autorun.* /f /s /q /a
del e:\autorun.* /f /s /q /a
c, d, e each represents drive letters on Windows system. If there are more drives or partitions available, continue to command by altering to other drive letter. Note that you must also clean the autorun files from USB flash drive or portable hard disk as the external drive may also be infected.
7. In Task Manager, click on File -> New Task (Run…).
8. Type “regedit” (without quotes) into the Open text box and click OK.
9. Navigate to the following registry key:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
10. Check if the value name and value data for the key is correct (the value data of userint.exe include the path which may be different than C drive, which is also valid, note also the comma which is also needed):
“Userinit”=”C:\WINDOWS\system32\userinit.exe,”
If the value is incorrent, modify it to the valid value data.
Anonymous
  • Posted on Sep 18, 2008
SOURCE: E:\ application cannot be run in win32 mode
dsf
Anonymous
  • 73 Answers
  • Posted on Jun 01, 2009
SOURCE: SkypeSetupFull.exe is not a valid win32 application
the software you downloaded is corrupt please try to download a another setup.
http://www.filehippo.com/download_skype/
Peter Dragonetti
  • 798 Answers
  • Posted on May 26, 2010
SOURCE: skypesetupfull.exe is not a valid win32 application
http://download.cnet.com/Skype/3000-2349_4-10225260.html
Try to download the file on the link above, any more problems let me know.
You can also get skype portable (this you do not have to install but you can have it in a folder of your choise) :
http://portableapps.com/apps/internet/skype_portable
REMEMBER for use Skype you have to make a account you have to use the default sign up in the program or this link :
https://login.skype.com/account/login-form?application=download&return_url=http%3A%2F%2Fwww.skype.com%2Fgo%2Fdownloading
Have a nice time over there
Anonymous
  • 516 Answers
  • Posted on May 30, 2010
SOURCE: Not a valid Win32 application
Answer:File is corrupt, bad, or missing
If the file or program you're attempting to run is corrupt or missing, Windows will be unable to execute the file properly and sometimes generate this error message.
Download files
If you downloaded this file and verified it is complete and compatible with your version of Windows, delete the file and try downloading and running it again. It's possible during the download that the file became corrupted.
Finally, if the second download does not work, try downloading the file from a different webpage. It is possible that the person or company maintaining the website mistakenly uploaded a corrupt version of the file you're attempting download.
Installing a program from a CD or other disk
If you're attempting to install a program and are getting this error, verify that the CD is clean. If the CD is dirty or bad, you could get this error during the install and/or get this error after the program has been installed because it was not copied properly onto the computer.
  • Additional information about cleaning a CD can be found on our cleaning page.
Running a program from the computer
If you're running the program from a shortcut on the computer, verify that the program is still on the computer. In some cases if the program is no longer installed on the computer you may get this error.
If the hard disk drive is corrupted or bad it can also cause working programs to fail either because not all the data can be read from the hard disk drive or because the program has become corrupted while on the drive. Run scandisk and defrag on the hard disk drive to check for any potential errors.
Long file name issue
Make sure the program or file you're attempting to run does not contain the same name as the long file name directory it is contained in. For example, executing a file named "program" in the "program files" directory can cause errors in some versions of Windows.
Additionally, if you're attempting to install a program and after the install the program does not work, you may also want to try installing the program in a different directory.
Bad file
Any file can be changed or renamed to be a .exe file. If you're downloading the file, make sure the file is supposed to be a .exe file and that it's not being changed. If you're attempting to create a .exe, file make sure you're compiling the file for Windows and never just rename a file to a .exe file. For example, renaming a .bat file to a .exe file will not make the file an executable file. For a file to become an executable file it needs to either be compiled or converted through a software program designed to convert the file.
File is not designed for your version of Windows
If you're trying to run a program that is not designed for your version of Windows you may get this error. Although many older programs designed to work in older versions of Windows will work with new versions of Windows, unfortunately, not all programs will work.
  • If the program is an older MS-DOS program or early Windows program you may get this error.
  • If the program is designed for a 64-bit version of Windows and you're running it in a 32-bit version of Windows, it will not work and generate this error.
If you're attempting to run an older computer game in a new version of Windows, see document CH000587 for additional suggestions about getting older games to work in Windows.
File is a virus, worm, or other malware file
This error can be generated by a file that is a virus, worm, trojan, or other type of malware file. Often, this will be caused because the virus scanner installed in the computer will not allow the file to be installed or run. Try scanning the file to verify it is not a virus and/or infected.
If the file has been checked and is clean, it is still possible that the virus protection program and/or another program installed on the computer is causing issues during the install or execution of the program. Boot the computer into Safe Mode and try running the program; booting the computer into Safe Mode will make sure nothing is running in the background that could be causing this issue. Additional information about Safe Mode can be found on document CHSAFE.
Hardware incompatibility
If you're getting this error during the installation of a program it's also possible that the CD-ROM drive or the drive you're installing the program from is not compatible with Windows or has drivers that are not compatible with Windows.
Download the latest drivers for your CD drive or other drive through our drivers page.
Hi I am Farah, and as I wanted to download java , it came thet" " is not valid win 32 application'. What shoudl I do? Thx
It is possible that you are attempting to install a 64-bit version of Java when you have a 32-bit operating system. Check your operating and confirm this. In Vista you can find this using Start > Control Panel > System. This is similar if you have Windows 7. Here is what it looks like:
If after that you, you follow these instructions from Sun (Java) to locate and install the 32-bit version.
Error: x64.exe not a valid Win32 application This article applies to:
  • Platform(s): Windows 7, Vista, Windows XP, Windows 2000, Windows 2003
  • Browser(s): Internet Explorer, Firefox, Mozilla 1.4+
  • Java version(s): 6.0
SYMPTOMS
While trying to install Java a user gets an error message similar to:
' ... x64.exe not a valid Win32 application'
CAUSE
The error message is a result of trying to install a 64-bit version of Java on a 32-bit operating system.
SOLUTION
User needs to install a 32-bit version of Java software, since a 64-bit version is not compatible with their 32-bit operating system.
Follow these steps to download 32-bit Java
  1. Go to Manual download
  2. Click Windows XP/Vista/2000/2003/2008 Online.
  3. The File Download dialog box appears.
  4. Choose the folder location.
  5. (Save the file to a known location on your computer, for example, to your desktop).
  6. Click Save.
  7. Close all applications including the browser.
  8. Double-click on the saved file icon to start the installation process.
I cant format my window because when i click that will give me that ''not a valid win32 application''
Exactly what are you trying to format? Usually you cannot/don't want to, format the drive you are working on? "not a valid win32 application" usually means, that the program you are trying to run, is a DOS based program. Formatting is usually done via DOS.
Win32 app error for every application opened. the last thing i downloaded was updates for my hp laptop after stating it had updates available. i can't go to anything , tried accessing control panel to...
Do a system restore. start>all programs>accessories>system tools>system restore.
or in vista: just type system in the start search and click on system restore.
Win32 application not vaild
The application is not supported by the win32 system file of your windows XP
Hi, recently i had virus in my comp called win32.worm.autorun.MQ i restored my windows through restore after cleaning up when i click on my drive it gives me error saying "resycled\boot.com is not valid...
This is a solution i found at another site that i think could help you with your probem
Hi
If you still need help with this please do following:
Download and install TrendMicro HijackThis
* Once installed open HijackThis by clicking Start > Programs > HijackThis and click the button labeled
Do a system scan only
* Click the scan button in the lower left hand corner of the interface and HijackThis will quickly scan your system.
* Once the scan is complete the scan button will now read save log. Click this button to save the log file to your PC. Once you select where you would like to save the file it will open in your systems default text editor. Typically this application is Notepad. Post the log here.
The link:http://www.techsupportforum.com/security-center/virus-trojan-spyware-help/hijackthis-log-help-inactive/306207-resycled-boot-com-not-valid-win32-application.html
Please let me know if you need more help with this problem
3answers
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
