SOURCE: kitchenaid top load washer wont agitate or spin
you have a direct drive washer with a coupling broke.Here is a good article on it http://repair2000.com/coupling.html
SOURCE: Whirlpool Ultimate Care HD Plus Model #LSR8233EQ0 won't agitate or spin
It sounds like the coupling between the motor and gearbox has worn out. It should cost around $15 plus shipping and handling.
SOURCE: Washing machine will not drain.
I have the same problem. If I press on the lid by the switch it starts up and finishes the load. Hope this works for you!
SOURCE: I have an auto sensing load whirlpool washer,
is it still under warranty but anyway there is a water fill level switch that controls the water level and when it reaches the setting u have it on then it shuts the water off and the wash cycle kicks in most likely bad or it may have a small hose on it that is crinkled off or stopped up
