Microwave Ovens Logo
Joe Miloser Posted on Sep 29, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
GE MICROWAVE OVEN JVM1190 CONVECTION NOT WORKING
Poppa Maddo
Level 2:
Sergeant:
  • Expert 372 Answers
  • Posted on Oct 18, 2019
Poppa Maddo
Expert
Level 2:
Sergeant:
Answers
372
Questions
0
Helped
118755
Points
687
Convection needs fan drive to force the air into the oven cavity. The fan may be direct motor drive or belt driven. If the latter the belt may be broken or simply have stretched and come off.
Before removing the cover of the oven in attempt to carry out any maintenance such as replacing the Oven cavity lamp, make sure the oven is disconnected from the power point ! The voltages in a microwave oven ARE LETHAL !
5 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Jan 03, 2009
SOURCE: GE Microwave/Convection JVM 1090 oven won't reach temperature
You probably have a bad thermistor.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
(At that site, that part is misspelled as "thermister" for your model).
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Accessing some components for testing will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Anonymous
  • 776 Answers
  • Posted on May 26, 2009
SOURCE: GE COMBINATION MICROWAVE CONVECTION OVEN JVM1790BK CONVECTION OVEN DOES NOT GET HOT
change the tube/heating element
Woody J Hiatt
  • 306 Answers
  • Posted on Jan 31, 2010
SOURCE: I own Microwave /Convection Oven JVM1190. I used
There is a small thermodisc temperature protector in the top of most MWO that cuts off power when over temp was reached or maybe fails all by itself.
I replaced two last year with resettable type but getting to them is a large job all by itself. RE: removing the top cover
Anonymous
  • 43501 Answers
  • Posted on Aug 07, 2010
SOURCE: The microwave part of GE profile JVM1190
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
tbreeze47
Tom Carson
  • 3083 Answers
  • Posted on Sep 22, 2010
SOURCE: Have GE JVM1190 microwave-convection oven
This sounds like a capacitor breaking down on the main control board, while the microwave is cycling, then when it stops to go to the default display, it's not allowing the display to power up. Another possibility is a bad timer, or a slightly oxidized pin on the control board, etc. Not your everyday problem, but you might get lucky if you go into it, disconnect and reconnect wires and connectors, and make sure they're clean (electrical contact cleaner, qtip and alcohol, or fine emery cloth).
Heed the warning in the following blog before you attempt to open it up and get inside:
http://www.applianceaid.com/component.html
Hope it's just a simple thing, and good luck.
GE JVM1190 Microwave Oven service manual
Question edited for clarity
Question mover from Motorcycles category.
Service Manuals for Microwave ovens don't normally exist because they are so DANGEROUS!
https://www.allrepairmanuals.com/ge-microwave-oven.htm
Other places that promise but don't deliver!
https://www.google.com/search?q=GE+JVM1190+SERVICE+Manual
Hoq do download a users manual for my convection microwave oven?
Go to this link Download GE JVM1190 Owner Manual
Look for the area on the page that looks like this (see below)
In the empty box, type the 3 characters that are requested
(sample HAF)
Then click on the blue rectangle that says "GET MANUAL"
Once the manual downloads,click on the file to open it.
What is the cubic feet for jvm1190
GE JVM1190 825 Watts With Convection Cook Microwave Oven. 1.1 Cu.ft. 825 Watts output power
1helpful
JVM1190 wont cook
You have a blown actuator. This is the device that creates the microwaves that cook the food. The cost of one of these will be as much as a new unit.
GE JVM1190 control pad
It is not your key panel, but the magnetron inside the microwave that is causing you the problem. The reason it does not short out on defrost or convection is because it is not drawing as much current through the magnetron to short out.
Ge JVM1190 appears to be working but does not cook.
I spoke with a qualified microwave technician who advised me to buy a new microwave as the problem I was having indicated that the magnetron tube had blown. What a waste of time to ask for help from you.
Looking for Temperature probe for JVM1190
Most any standard microwave temperature probe should work, from places such as Wal-Mart, Home Depot, Lowe's, etc.
GE JVM1190 microwave oven light comes on, but no the FAN or "microwaves"
If it were just just not cooking, I would suspect the magentron. But since the fan is also not working, I think you have a bad door switch. If you or a friend decide to work on it, we have *critical* safety and disassembly info at our site, as well as other specific troubleshooting information and help. In my professional opinion, no one should work on a microwave unless they are fully informed and aware of the deadly hazards and necessary precautions. You can find safety and disassembly text files (as well as a text file which helps in diagnosing and repairing door switch problems) at http://www.microwavedisplay.com You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
