I want to print an invitation, the paper size is 5.5in x 8.5in when i want to print it tells me that the paper size is wrong...but i don;t know how to fix that because it won't show that size
Good day, Regarding the error message that your getting, that means the paper where you want to print that document is not supported by the printer. Usually you'll the see supported paper size if you click the print option or print setup for your printer. The only way to resolve this is to use the appropriate size of paper like.
You can also try this steps to change size for the documents you want to print
>Open the File menu and click Print. >Click the Settings tab >Click on Paper Size. A list of paper sizes will appear >Select the size you want. >If none of the selections are suitable, select Custom. A box will appear
inviting you to set your own measurements. Enter the width and length
that you want. >Click OK.
These are the usual paper size use. It's 8 1/2 by 11 inches and the other one that you could use in most printers is 8 1/2 by 14. The first one is known as Letter size, the other one is known as Legal size. Hope this information help in resolving your issue. Have a great day.
This is common with these printers. When you go to print and the kodak dialog print box comes up you need to change the paper size manually for the printer. The printer does not always take the correct paper size from the program you are printing in if it is a custom document.
another word of advice. USE THE TEST SHEET FIRST. This printer does nto correctly print invitations you need to offset the items about 1 inch to the right or so. Test before you print the real things.
I think it's more or less the same on Mac or PC. Hit Print in your software, then when the dialogue box comes up you should see several options settings. There will be a pull-down menu that lets you choose paper size. (This menu is sometimes buried in another sub menu called "printer options" or something similar. It can be tricky to find this in some apps like Photoshop). Just select your 5x8 size and then at the top of the dialogue box you should be able to save it all as a preset. Pull down the "preset" tab and select "Save As..." then you can name it and pull it up each time later.
Hope this works.
The error that you are getting is telling you that the paper size or type you picked in setup is not what the printer is detecting. Once you verify that you did choose the right type & size, the next thing to check is to make sure the paper path is clear. If a piece of paper is covering a sensor this might cause the message to appear. If you don't see anything in the way, take a can of compressed air and blow out the path.
Okay, go to your printer folder Start/Printers Right click on your printer (Officejet 6310) and click on Properties. You will see a button near the bottom called Printing Preferences. Here is where you choose your paper. You can make your choice here and choose to make it your default settings (click Apply to make the new paper your default to print your invitations...you will have to change back after). You may change the quality of print and paper type as well since the default setting won't provide the quality of print you desire. From here it's pretty straight forward. Feed your invitations into the paper tray as you would normal paper and try a test print for quality control. Once you've got the desired output, print the rest of your invitations.
Change the size of the document on word to a standard sized document - such as 8-1/2 x 11. Then when you go to print the documents, set the printing preferences to print on 5x7 paper. That should do the trick.
