I have not yet found a manual online for your Baby Lock sewing machine.
Therefore, I suggest you contact the Baby Lock company directly and ask about the availability of a manual for your model sewing machine: https://www.babylock.com/support/contact
There may be a charge for the manual.
Ooo ouch! sounds like you have a pretty bad timing problem and or a damaged bobbin case. Since it is a baby lock I would suggest taking it in for repair.
BRAND new Janome 1420qdc. New needle, doesn’t need oil. Will NOT wind a bobbin. Used almost an entire spook of thread doing this. At my wits end. HELP!
You do not have a Singer, you have a Babylock. You can try some places online, such as www.sewingpartsonline.com or Babylock themselves. It looks pretty standard, #15 bobbins etc. I don't know what parts you need, but check out places online or a local dealer.
hi!there similar bobbins winder in any brand of sewing machine uses mostly in domestic particularly in industrial manufacturing in this fig.check it out if similar to your bobbins any how itmay be helpfull onethe bobbins winder that was a thread and shoul be clockwise rotation when coming out to bobbins case,if you to wound the thread on your bobbins winder, pull threads on spool then wind this in several times 4 to 6 rotation clockwise loop thread on top machine there is bobbins winder disc for tension put winder bobbins on shaft winder near hand wheel push the latch against bobbins winder to fit thead run machine to wind the thread.After hread wound in bobbins winder cut thread and insert winder to bobbin case as shown. insert bobbins to shuttle hook case under needle foot holder
lift the cover plate you can see under this is the shuttle hookafter set up was made on bobbins thread,set also the upper loop thead beginning at top of machine start on spool, pull thread and loop to upper disc tension then to the slot portion as in figure
insert on lever dial goes to the needle adjust tension to #8 range to #12 for cotton fabrics two layer sewing.
the bobbin winder on my BabyLock Denim Buster dosen't worh either!
