SOURCE: 99 navigator blower stays on after turn off and keys are removed
your problem is a bad blower relay..... it is located under hood in fuse panel about a $20 part
SOURCE: sudden stops
Sounds like the brake. Ohm chech the brake (it is attached to the end of the motor). It should be around 35 ohms
SOURCE: 88 cadillac deville, ac blower fan wont shut off,
Ralph,
Most common cause of this is the blower fan (proper name for the fan you refer to) continuing to run is a shorted out Electronic Climate Control Module. This solid state device replaces the older style fan speed resistor block (at about 4 times the price) This unit is found on the top of the HVAC box under the hood. (HVAC means heating, ventilation and air conditioning) The HVAC box is found on the passenger side of the firewall. Look behind the A/C's accumulator. It will have an electrical wiring plug on top of it. It will be fastened to the HVAC box with a few 7mm hex head screws. Very easy to change.
FYI, do yourself a favor and replace the blower fan motor at the same time. The Electronic Climate Control Module usually fails because the motor is drawing to many amps of current. This is because it's bushings are worn out or the brushes are worn out.
This is very common on Cadillacs and Buicks.
Charlie
PS Not sure why car won't start. Either you drained the battery or blew a fuse which controls starting the engine. Need more info regarding the "no start" condition.
SOURCE: Fan blower started running full speed, ...
THE FAN BLOWER RELAY IN STUCK CLOSE POSITION.YOU HAVE TO REPLACE FAN BLOWER RELAY.
SOURCE: Electric 3 wheeled mobility scooter wont move
Look at the rear of the scooter, make sure the Free Wheel lever is engaged
