Hi Roberto, if you can use the UBT-1 unit on your Onkyo HT-R990, since it has a USB input
Regards Franco Dosil
Hola Roberto, si puedes usar la unidad UBT-1 en tu Onkyo HT-R990, ya que este cuenta con entrada USB
Saludos Franco Dosil
https://www.intl.onkyo.com/downloads/manuals/pdf/ht-r990_manual_e.pdf
https://www.eu.onkyo.com/downloads/1/4/7/1/2/Manual_HT-S9405THX_Es.pdf
SOURCE: remote control codes
Here is a link for the complete manual :
http://www.us.onkyo.com/download/own_manuals.cfm?cat=Receiver
remote codes start page 61
To control an Onkyo receiver with a universal remote try code 0135
Hope this helps
Alex
www.CustomAutomaticSystems.com
SOURCE: onkyo HT-R560 receiver
The unit most likely blew up a capacitor. If you look in through the slots on the top of the unit you should see 2 big black caps (C6901 and C6902) with shiny silver-ish tops. I should also point out that you probably flew up a 125v 8A (F901) glass fuse on the board that the AC cord plugs into. The glass fuse can be found at Radio Shack, but the caps are a bit more troublesome to find. They are 10,000uF 69v and thats just not a standard part, so you may need to up the voltage requirement and buy a 75v cap. Total to fix the amp yourself: Should be about $35 with shipping.
SOURCE: My Onkyo HT-R510 will shut down after several
Might be over heating. Make sure you don't have anything sitting directly on top of it. I even put a little fan blowing outward at the back of my system to keep it cool.
