SOURCE: Different language, help!
The icon to change language is three flags, and looks like this:
It should be located within the Preferences (wrench) which can be accessed from the main menu.
SOURCE: changing the language
Turn on your machine. The SET tab is the fifth from the left (or second from the right). Touch that.
You now need to touch the More button, which is on the bottom row and is the button on the left hand side (there are two buttons at the bottom - More and OK).
On the next page that comes up, the LANGUAGE select button is the single orange button at the bottom of the list. The two buttons at the very bottom are once again More and OK, so go above them to the single orange button. Each time you press this, the language changes. There are quite a lot to scroll through, but keep pushing it until English comes up again.
That should fix your machine for you. No suggestions on how to fix your husband, though!
Pamsquilt
SOURCE: I was programming it and
enter code *#7880# it reset your setting.when you enter your mobile ask security code enter security code then your mobile restart come back on default settings
SOURCE: how do i change language?
Press the Menu button. Select Setup (the wrench icon, or else the last item). Select Language (either the waving flag icon, or else "xxx/Language" where xxx is Language in whatever language is currently selected. No matter the language, it should still say "Language" in English after the slash. In that menu, each language is labeled in that language, so you should see "English" as one of the options. Select that, and everything should be back in English.
SOURCE: change language back to english
Press the MENU button. Use left/right to select the Setup tab. Use up/down to select the fourteenth item on this menu.
