Https://www.google.com search suggests possible solutions, including part replacement:
https://forum.support.xerox.com/t5/Hardware/Workcentre-6515-Device-Fault-062-380/td-p/214038
https://printcopy.info/?l=en&mod=erc&brand=Xerox&model=WorkCentre%205019&code=062-386
SOURCE: Xerox WorkCentre XL2120 Vista Compatable Driver
Here is the answer from Xerox
Windows Vista Note: There are no plans to develop Vista drivers for the Xerox Small Office/Home Office products. Please check with a Xerox Sales Representative for the latest products with Vista support.
SOURCE: reset WorkCentre 24, Xerox
In menus you browse to the service tab, then serivice diagnostics. Go to NVRAM reset and perform the NVM reset.
Before you do that, print out a configuration page if you want to rememebr the network settings. It will set the IP address back to default also.
SOURCE: Xerox Workcentre Pro 123 error code 016-719
this is not a mechanical error but a software error.
It either doesn't recognise the format or program
as for the driver don't thinkit's the problem the HP can use PCL6
SOURCE: xerox workcentre m20i power off
First off try unplugging it and leaving it unpluged for 30 minutes. Not just turned off, but unplugged, then plug it back in and see if it works. There are filter capicitors in the low voltage power supply that sometimes have to sit with power removed for 30 minutes before they discharge and allow the power supply to turn on.
Sounds weird but I have seen it fix a dead machine probably 50 times or more. If that doesn't restart then you will have to replace the power supply. If that is the case let me know and I can tell you where to get it from and ho\w to replace it.
Try leaving it unpluged for 30 minutes. not less than 30 minutes.
SOURCE: My Xerox Workcentre-5020 machine showing
@basanta711, Press 0 for 5 seconds then press green (start) then 50, green, 20 green, 0, green then on/Off the printer........... problem is solved
