Question about NorStar T7316E Corded Phone
Caller ID not working on my t7316 phone
My phone stopped showing the caller ID, how do I turn the caller ID function back on? (yes, I have the service for caller ID...the other phone shows up just fine, for some reason the 2nd phone doesn't show anything when you pick up or when there's an incoming call.
  • 11,896 Answers
You can copy and paste this link below to go to a site where you can download your entire manual:
http://www.alphatelecom.ca/meridian_norstar_manuals.htm
Posted on Sep 16, 2009
  • yamama40 Jan 05, 2011
    ABOVE LINK NO GOOD BECAUSE USER MANUALS HAVE NO INFO NO HOW TO FIX CALLER ID ISSUES.
SOURCE:
Just bought KX-TGD225 phone system and can't get the caller Id function to work even though I subscribe to caller ID with the phone company. The talking caller ID works but no display on the phone
Please call your phones service provider, they may charge for this service. Just because the phone is capable of caller ID function doesn't mean it is a free service.
Jun 21, 2016 | Panasonic NEW Expandable Digital Phone...
My t7316 is no longer ringing at my desk or showing the caller id
You can set the ringer volume by using Feature *80 and use the volume control to change the level. If this does not get your phone to ring again, then the line assignments will need to be reprogrammed.
Mar 19, 2013 | NorStar T7316 Corded Phone
Caller id doesn't work for iphone 4
Caller ID is a staple in every iPhone. Your service provider may have blocked your Caller ID, so make sure to check with them first. To check if your iPhone has enabled the Caller ID setting:
1. Go to settings.
2. Click on Phone.
3. Click on Show my Caller ID, and select Yes.
Jun 14, 2011 | Apple iPhone (16 GB) Smartphone
No caller ID. TP company says I have service.
  • Did you fully charge your phone? - Make sure you fully charge for 16-24 hours .
  • Is the battery old? - Replace the battery.
  • Is the electrical outlet switch turned on? - If you are using AC (electrical) power, make sure that the unit is connected to a non-switched electrical outlet.
  • Are the connecting wires tight - Unplug the AC power converter from the unit and plug it back in.
  • Do you have Caller ID service with your telephone company - In order to receive Caller ID records, you must subscribe to the standard name and number Caller ID service available through your local telephone company. If the Caller ID works for normal calls but not on Call waiting calls, then you must contact your phone company to get the combined CID/CW service.
  • Caller ID shows up after second ring - Be sure to wait until the second ring before answering. Caller ID signals comes through after the first ring, if caller pick ups phone too soon Caller ID signal will not be transmitted to the handset.
  • Confirm that caller ID is still working on that particular line by checking another phone on the same line - If Caller ID is not coming through contact your phone company provider.
If this does not fix your problem, contact your authorized Service Center.*
Oct 16, 2010 | Uniden DECT 6.0 Cordless Phone ID
Caller ID stopped working
use this link to get the phone user manual. In page 28 it has the details of the Caller ID's. Post us back if your problem not solved
Jun 10, 2010 | Panasonic KX TG2237S Cordless Phone...
Caller Id function...How do I turn it on?
You dont normally have to "turn on" caller ID on a phone capable of displaying caller ID.
However, the caller ID data the phone has to pick up off the phone line when a call comes in is normally an additional (paid for) service from your telecomms provider.
Have you specifficlally requested the caller ID service from your telecomms provider ? If so, have they confirmed it is now up and running ? Are you sure your phone is caller ID compatible ? Can you borrow a phone from somebody, that you know dsiplays caller ID and try that phone on your line ?
If the answers to these questions is yes, then you need to report this as a fault to your telecoms provider who, so long as the answers to the above questions really is yes, wont charge you for rectifying the problem.
Sep 30, 2009 | Lands Phones
My line one caller ID is not working, but my other lines are.
Partner gets caller id from a carrier. If you have a caller id service it will show on your 18D
Dec 09, 2008 | Lucent PARTNER18 Corded Phone
Uniden Cordless Telephone with Dual Handsets and Caller ID DXI-55
check if you have a manual. from there search up in the manual caller id settings. you have turned off the caller id option.
Nov 15, 2008 | Uniden Cordless Phone
Uniden phone 5.8ghz
Make sure that you have caller id service from your phone company. If you do not have a different phone with caller id borrow a working one from a friend and see if it shows up on a different phone. Let a phone ring at least twice to give caller id time to work. If a different phone does not show the call information call your service provider.
Jan 28, 2008 | Uniden TRU8885-3HS Digital Cordless Phone
NorStar T7316E Corded Phone Logo
988 people viewed this question
Top NorStar Lands Phones Experts
Marvin
Marvin
Thomas F. Schneider
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
