When calls come through , receive and reject signs come up , press green to receive then nothing???
Hi friend,
Don't worry!
This is probably you have set the "call barring" ,You can
confirm if you have set this as the following:call center-General call
settings-SIM1 call settings-call barring-incoming calls-All calls/When
roaming,if you have set your cell phone under this condition,you can not receive
the incoming calls, you can try to cancel this setting to see if you can receive
the incoming calls.
Or you have set the "Line switching",you can check
this as the following:call center-General call settings-SIM1 call settings-Line
switching-Line1/Line2,some cell phones can only receive the incoming calls when
they are under the condition either "line 1" or "line2" ,if you cannot receive
the incoming calls when they are under the "line1" condition,you can try to
swith it to the "line2",but if you cannot receive the incoming calls when they
are under the "line2" condition, you can try to switch it to the
"line1".
If you found it still cannot work after you doing the above,you
may confirm if you cannot....you can get much solutions of the problem here:
http://www.1010store.com/forum/viewtopic.php?f=2&t=227
SOURCE: cant get the phone to vibrate on a incoming call
Lorraine,Go to Settings->Sound->In Coming->Alert type. Select Melody and Vibration. Or similar settings. But it has to be connected to your In Coming Calls.
