MATSUI MAT 120 MR (sigmatel) My mp3 player will not turn off
Hi!I did flash
firmware using stupdaterapp.exe OK! BUT then to turn my mp3player - MATSUI MAT
120 MR (sigmatel) off I can't use the off switch I have to remove the battery.
And Menu dont work as well. could you please help me.....
Lara
If your Matsui is working suggest you leave well alone -- I've been looking for utilities (new firmware, reflash utility and firmware extractor) and it's all very confusing.
Apart from the ghastly menu system the only problem I've had with mine £8 ($16 used from a flea market) is that Win XP's data write-behind feature means that XP merrily suggests that file transfers are complete when the player is still digesting the files. If you interrupt this by mistake XP stops responding or complains that data has been lost.
Hi
when i connect it to computer ; computer detect it as STMP3500 ; i download STMP3500 Driver from internet and then install it to Computer but already Computer Don't detect my mp3player;
then i run MuVoS200_PCFW_A5_1_02_02.exe but at this time computer detect my mp3player as MuVo S200 Then i upgread my Firm ware.
Now it work very good.
1) Disconnect from computer, turn it off, hold in volume + button and reconnect it to your computer - continue holding volume + until the Found Hardware Wizard comes up. 2)
REFORMAT FOR WINDOWS MEDIA PLAYER - Erases Everything: Connect your iLo player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "ILO 2GB" (wording may vary slightly), and then select "Format." - this should erase everything, and give you a fresh start.
If you can check the rechargeable batteries try that. If you plug it into a wall socket with the adapter and nothing happens you might have other major problems. Just a little education: when you buy something especially from other countries alway check it before leaving to make sure it works. Unless there is a company that you can send the warranty unit to you may be out of luck. Sorry.
Try to reformat it. If that is not your solution then reflash your firmware from the small CD you recieved with your MP3 Player. If you don't have that software you will find it at the following link:
Download it and open the the " programs " (There is only one) Once you'e in that folder.... double click on this folder "stupdaterapp.exe" Just simply follow the instructions and you should be fixed.
