RECEIVED IN MEMORY
If the machine receives a fax under one of the following conditions, the machine will not be able to print the received fax and will store it in its memory.
When the problem is resolved as described, the fax stored in memory is printed automatically.
Ink is low or has run out while receiving a fax: replace the FINE Cartridge.
Paper size/type setting is incorrect: correct the paper size/type setting.
Paper has run out while receiving a fax: load the paper and press the
OK button.
Output Tray is closed: open it.
OFF is selected for
AUTO PRINT RX: select
ON.
You pressed the
Stop/Reset button to cancel printing of a fax: press the
FAX button.
