SOURCE: golden companion 2 scooter moves slow in reverse
i would suggest there is either a loose connection or the speed control has failed, the scooter will still run but at a slow speed, the part is fairly standard in all scooters. if i can be any furthur assitance please email me rick @ lxrixta.co.uk (remove the spaces)
SOURCE: Golden Tech Companion II: Doesn't go, batteries
Accessibility Specialists Inc
1815 Corporate Sq Blvd
Ste 200
Jacksonville, FL 32216
(904) 725-0601
SOURCE: where can I find the serial # on my companion
Depends on the age of the scooter. It could be on the seat post between the batteries or under the floor mat.
SOURCE: Golden Companion Scooter not moving - diagnosed via owner manual
Hi. Many scooters will display this fault code if the potentiometer is not exactlly centred when you turn on the key. The pot is not always faulty. Some scooters also have a smaller additional pot to controll the speed. If this pot is faulty it will cause the same fault code. Any other switches such as indoor/ outdoor switches. I have had a few machines fitted with curtis controllers where the fault is in the controller.
Check the wiring and plugs and connectors.
Good luck. Neil.
SOURCE: Stops intermittently, stops when going
Check for lose or bad connection to the battery, or the on and off switch.
