Cell Phones Logo
D
Donna Kaye Posted on Sep 26, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi my zte blade v8 wont charge.its turned on and it says charging theres a green light flashing then no light
ABEL OTERI
Level 2:
Habit-Forming:
New Friend:
  • Expert 44 Answers
  • Posted on Sep 27, 2019
ABEL OTERI
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
44
Questions
0
Helped
8285
Points
112
5 Related Answers
Anonymous
  • 8 Answers
  • Posted on Jan 29, 2008
SOURCE: no 'green' light on bacl of my 'old' Vivitar 285
Then I'd say it's a reasonably sure thing that the green light is just burned out, The lights are supposed to be off at first, then red when there's a partial charge, then green when there's a full charge, then flashing between red and green when the "battery saver" kicks in. If you're seeing off, then red, then off, then flashing red, then that means everything in the charging circuit is working perfectly, there's just no green light.
Walter H Boehm
  • 998 Answers
  • Posted on Nov 09, 2008
SOURCE: Dell latitude D600 battery charge light flashing
That usually indicates battery is beginning to go bad. Eventually it will not hold a charge and will need to be replaced.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Rodie
  • 629 Answers
  • Posted on Mar 16, 2009
SOURCE: Battery Charge light flashing 4 red one green Dell Inspiron 9200
usually, its an indication that the battery is nearing the end of its useful life. you can try to use another battery to isolate it further. If the same thing happens with another battery, chances are, the mobo is failing. Flashing the BIOS can usually help with battery issues. If another battery works fine and your computer is within its first year since you bought it, you can request a replacement battery from Dell
Anonymous
  • 4 Answers
  • Posted on Jul 17, 2010
SOURCE: when charging the red light flashes for ten
If green flashes you will need to change batteries.
Repair Ahjoshe
  • 885 Answers
  • Posted on Sep 13, 2010
SOURCE: hi both red and green
If both lights are flashing it means the battery is defective so it won't charge it. By defective it could mean the battery is just worn out or there may be a short in the battery. If the battery is under warranty you can get it replaced at a Makita Service Center, if not you have to buy a new battery.
Testimonial: "thank you verry helpfull"
I bought a dyson V8 today when I plug the charger in a blue light flashes (slowly) is this OK does it mean it is charging properly?
Hi Yvonne, A flashing blue indicates that the battery is charging. No light indicates the battery is fully charged. A flashing red light indicates that there is a fault,
I have a skyforce gravity r/c helicopeter trying to fix for my son.When it is plugged in the charger, it just blinks green light. Have it over night, and it is still just blinking green. Have lost remote....
It means that the charged battery is full. Some chargers have a steady glow, others have a flashing light to show that the battery is charged. When you run the helicopter, is the battery fully charged, does the helicopter blades spin flat out? If so, the battery is charged and the flashing light indicates the battery is charged. If the battery isn't charged or the blades don't spin enough to lift the helicopter, or fly for some time, then the battery isn't charged and the charger may be faulty. Take it to a hobby shop to see where the problem lies, the charger and its blinking light, or the battery.
Dec 28, 2014 • Toys
Flutterby fairy charge with charger blinking
STATUS LIGHT will FLASH RED when
charging. Allow at least 30 minutes
for a full charge.
STATUS LIGHT will turn ORANGE,
and then turn off when charging is
complete.
STATUS LIGHT will FLASH GREEN
when the batteries in the CHARGING
BASE are LOW. Replace the
batteries.
STATUS LIGHT will FLASH RED &
GREEN when there’s a CONNECTION
ERROR. Reconnect the FAIRY.
1helpful
3answers
My air hogs switchblade's controler keeps turning off while its charging whats wrong?
always turn the switch blade off when charging it or it wont charge it and the red light goes off to save batteries on the controller..when done right it flashes red..only when it's flashing red and green will it be charged
19helpful
2answers
Motorola RAZR2 V9 new phone wont charge
Spare Battery Charger - Motorola RAZR V8 /V9 - $14.95
will need also a USA/Uk power adaptor /converter to use in Uk.100% works by charging battery separately from mobile
Top ZTE Cell Phones Experts
vince
nexrad_chris
Paul Carew
Are you a ZTE Cell Phone Expert? Answer questions, earn points and help others
