Hello, my Nespresso Essenza c101 does not turn on anymore (all lights are off) and since it's a machine I bought abroad (and quite old) the repair shop cannot find the necessary replacement part (main board) through their usual channels. They agreed to make the repair if I find the required part but I am not sure what to buy. I found the CB for seemingly identical machines with different model numbers (such as C91) but I am not sure whether they are compatible. Is there a way to find out what is the part number for the circuit board I need so that I can buy one that is compatible?
SOURCE: Capacitor assistance required.
ok people lets not make this so difficult.
you need 3300 mfd/ 10 volt electrolytic capacitors.thes are general purpose capacitors. the 105 t C is temperature tolerance.no big deal 85 c or 105 c is fine. try google search for MCM electronics, or Pacific Coast electronics or anybody that sells electronic parts
SOURCE: nespresso essenza problem
It's not supposed to make holes in the capsule until the water comes through. So, basically, when you put the capsule in, it pierces the capsule in three spots, on the top. The aluminum part will not pierce until you press the button and water comes through. If water is not coming through, then you can clear the air bubble by opening the lever on top of the machine, pressing the coffee button, and then closing the lever once the water begins to come through.
SOURCE: compatible part needed for 4407-BESK4H
This is AO4407. You can replace it by any 30V P-Channel MOSFET, for example FDS4435 or other.
SOURCE: water not coming through nozzle of nespresso essenza
I have had this issue.
I have removed round silver plastic piece from around coffee spout,(gently -do not crack it) I then removed and washed the black spout, I even used a toothpick once, to remove the stubborn coffee ground, Once it was cleaned - it worked perfect. If you run water from the faucet into spout it should flow smoothly. I warn you though, not sure what this does to any warranty, but don't mess with my morning coffee! I hope this helps.
SOURCE: Nespresso Krups essenza manual XN2001- Switch broken
The machine is not switching on-I am in India-Tamilnadu-can i get it serviced any where here?
