Question about Bosch Washing Machines
Do you need to reset the E13 code after replacing the drain pump in a Bosch Nexxt 500 series washer?
Replaced the drain pump. Pump still doesn't come on. Works fine until it's time to drain in the rinse cycle.
SOURCE:
catriver
  • 878 Answers
SOURCE: Washer will not pass wash cycle...Will not Drain
Nightshade, in most cases, no spin, no drain is a lid switch problem. If you advance the timer to the spin position does it spin? If the machine is agitating you can rule out the coupler. If you are sure that it is not a lid switch problem, then you are probably looking at a bad timer....Catriver..post back.
Posted on Nov 08, 2006
SOURCE: e13 error code with my
I had an E-13 error code on my Bosch 500 series washer.  The drain pump  impeller was plugged.  Access the drain impeller at the bottom front right corner.  Just put a pen in the hole and turn the cover.  Then you need to manually drain the washer.  I used a shop vac by just turning the cap until it started to leak and vacuum the water as it comes out, this takes quite a while.  When you get it drained you can take the cap completely off.  When I did I found a wipe in the impeller.  I took it out and put it back together and the washer worked just as before.  Good Luck!!
Posted on Mar 24, 2009
barkencoa
  • 3463 Answers
SOURCE: Bosch Nexxt 100 series front load washer
You first of all need to check the pump filter.
This should be located at the botom front right of washer.
Look for a drop down flap or cover, once located, unscrew filter anti-clockwise to remove and clean.
The pump itself is directly behind the filter housing, check there is nothing stuck in the housing.
This should solve the prob.
Please leave feedback for my solution.
Thankyou.
Posted on Jan 11, 2010
Testimonial: "I submitted a question and got a very quick response. The response was useful and enabled me to make the repair myself. Thank-you!"
barkencoa
  • 3463 Answers
SOURCE: bosch 100 series will not drain
You need to check and clean the pump filter if you have not already done so.
This is located at the bottom front right of washer.
Unscrew anti-clockwise to remove and clean.
Posted on Mar 15, 2010
  • 414 Answers
SOURCE: Bosch 500 washer won't finish rinse cycle. Flashing error code13
Timed out on drain cycle, basically you either have an outlet blockage or something is trapped in the pump, you can check the pump by opening the bottom right flap on the front panel,manually emptying the w/m and checking the pump filter for coins etc. Also, check the outlet isn't blocked.
Good Luck.
Posted on Jul 12, 2010
Can you tell me what e13 means on my bosch nexxt 500
Timed out on drain cycle, basically you either have an outlet blockage or something is trapped in the pump, you can check the pump by opening the bottom right flap on the front panel,manually emptying the w/m and checking the pump filter for coins etc. Also, check the outlet isn't blocked. E13 means timed out on drain cycle, In other words its trying to drain and cant so it stops with that error code, Hope this helps,
Sep 19, 2011 | Audiovox Bosch 718 World Cellular Phone
THE bOSCH 300 SERIES WASHING MACHINE IS NOT DRAINING PROPERLY AND IT GIVES ME A MESSAGE e13. wHAT DOES E13 MEAN? pLEASE HELP
Hello, welcome to FixYa.
The E13 error code on most series Bosch including the "Nexxt" series washer`s refer to a drainage problem, as you may or may not already know. ( or in Bosch terms "pump time exceeded" )
Anyway, here`s the most likely way to remedy a E13 code.
**Unplug the washer from the wall or turn off the breaker before attempting any repairs, and a pair of mechanics gloves are recommended due to extremely sharp edges...safety first**
Get some towels and if possible a wet/dry vac. If the machine drained, it won't be too bad. If your machine is stuck full of water that is typically the reason for a locked door, that sucks...hopefully you won't get too wet. ( maybe you`re lucky enough to be close to a floor drain )
  1. Locate the round door on the front of the machine (about 6" in diameter, lower right corner) macmarkus_26.jpg
  2. Find a drill bit or small screwdriver that fits in the hole in the round door.
3. Insert the bit into the hole in the door. It will push in a tab, it doesn't take much force. Rotate the hole (clockwise) to 6'oclock and it should come free. (the edges are very sharp so be careful).
4. Once the door is out of the way you'll be greeted by a 3-4" plastic cap with wings so you can unscrew it by hand. ( you should also see a green ring with a string attached, if you pull this the door should unlatch, but getting the water out first is usually a good plan )
There is a small collector lip at the bottom of the cap, that is where you can hold the wet/dry vac to catch the water. Unscrew slowly so you don't get flooded, until it is unscrewed all the way out
5. Now pull out the trap and visually inspect the inside of the pump as well as the filter/trap. Hopefully you'll find the item/debris that initiated the error code.macmarkus_28.jpg
6. After removing any debris or obstruction`s re-install the button trap/lint filter and plug the washer in to power or reset the breaker and give it a test.
7. Run a load and watch for leaks. Leave the pump access door off until you are sure you screwed the cap in tight and there are no leaks.
Ultimately you may have a faulty drain pump, but I would certainly start by performing the things I listed first.
Let me know if you require further assistance and if not and this solves your problem, please rate the solution I provided accordingly.
Thank you for coming to "FixYa" and good luck.
Regards,
Macmarkus :)
Sep 01, 2011 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch E13 error on washer - shows e-13 and door will not open.
Hello & Welcome to FixYa
E13 error in your Bosch WFMC washer is a drain error and is displayed when the drain time exceeds & the washer is unable to drain so the door won't open sometimes when this error is displayed. You will have to clean the drain trap in the bottom right hand corner. You can stick a straighten paper clip in the access panel located inside the front bottom panel through the whole and then turn the access panel counter clockwise to unscrew the plastic drain cap behind it. After everything is cleaned and the error returns then replacing the drain pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Jul 30, 2011 | Bosch Nexxt 300 Series WFMC2201UC
E13
The E13 error code on the WFMC series Bosch washer`s refer to a drainage problem, as you may or may not already know. ( or in Bosch terms "pump time exceeded" )
Here the tips... support/t7599677-error_code_13
Apr 25, 2011 | Bosch Nexxt 300 Series WFMC2201UC
Error code E:13 on my 500 plus series washer
The E13 error code on your Bosch washer refer to a drainage problem or the pump time might have been exceeded
Either it might be due to a clogged pump, improper detergent being used, ( must use "HE" detergent ) hence suds not allowing a proper drain cycle. You should clean water drainage pipe and/or drain hose. Turn selector to off and restart 'drain, program or, on 500 plus machines, the 'refresh' program. It also says this is caused by using too much detergent. Bosch recommends using half of what the manufacturer recommends when using HE detergents. They don't recommend regular detergents. First run the short wash or refresh cycle without detergent and hopefully your lines will clear.
Thank you !!
May 25, 2010 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch front loading washer nexxt 500 won't pump out water on the spin cycle
could be drain hose is not high enough. I had the same problem and when I raised the hose it worked fine.
Dec 04, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Code E13
For a Bosch washing machine, Error 13 is pumping time exceeded. So, in general, the issue is pump related. Things to check would be if the pump is blocked (it can be cleaned out if you can get the service door in the front panel off), check the wiring connections to the pump, and check the drain hose to make sure it is not blocked.
Feb 14, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Washing Machines Logo
29 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
jimorris77
Dw Wooten
Dw Wooten
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
