2006 Ford Five Hundred Logo
Posted on Sep 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Needing engine bolt torque specifications for a 2006 Ford Five Hundred with 3.0 liter engine. This will need to include rod and mains torque and torque rotation.
  • Anonymous Mar 15, 2014
    torque specification for front stabilizer bushing bolt
  • Anonymous Mar 29, 2014
    Torque on arp rod bolts
Anonymous
Level 2:
  • Expert 233 Answers
  • Posted on Sep 16, 2009
Anonymous
Expert
Level 2:
Answers
233
Questions
0
Helped
109475
Points
966
Stage 1 tighten to 30 ft pounds
stage 2 tighten 90 degrees
stage 3 loosen one full turn
stage 4 tighten to 30 ft pounds
stage 5 tighten 90 degrees
stage 6 tighten 90 degrees
this is per mitchell on demand courtesy of ford specs on the lft and right head.
for some reason there are no torque specs on mitchell for connecting rods and mains.
Need torque for ford wlt 2.5L turbo main bearings and conrod bearings
The torque specifications for the main bearings and connecting rod bearings in a Ford WL/WLT 2.5L Turbo engine may vary depending on the specific model year and engine configuration. However, as a general guideline, here are the torque specifications for the main bearings and connecting rod bearings in this engine:
Main bearings:
  1. Torque the main bearing cap bolts in three stages in the following sequence:Stage 1: 30 Nm (22 lb-ft)
    Stage 2: 80 Nm (59 lb-ft)
    Stage 3: 90 degrees
  2. After the final torque of 90 degrees, check the bolt stretch with a torque angle gauge. The stretch should be between 0.15mm and 0.30mm.
Connecting rod bearings:
  1. Torque the connecting rod cap bolts in two stages in the following sequence:Stage 1: 30 Nm (22 lb-ft)
    Stage 2: 90 degrees
It is important to note that these torque specifications are general guidelines and may vary based on the specific model year and engine configuration. Always refer to the manufacturer's service manual or consult a certified mechanic for the exact torque specifications for your specific vehicle
Please can you help with all the torque settings for the cylinder head on Hyundai Accent 1.5 1995"
Nissan Frontier, Xterra 1998-05
Torque Specifications
Fig.
TORQUE SPECIFICATIONS
all readings in ft. lbs. Year Engine Displacement Liters (cc) Engine ID/VIN Cylinder Head Bolts Main Bearing Bolts Rod Brearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Lug Nuts Intake Exhaust 1998 2.4 (2389) KA24DE
1A Step 1: 22 ft. lbs.
2B 10-12 ft. lbs. plus 60-65 degrees or 28-33 ft. lbs.
4C The cylinder heads and the lower intake manifold are installed together
all readings in ft. lbs. Year Engine Displacement Liters (cc) Engine ID/VIN Cylinder Head Bolts Main Bearing Bolts Rod Brearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Lug Nuts Intake Exhaust 1999 2.4 (2389) KA24DE 3.3 (3277) VG33E
all readings in ft. lbs. Year Engine Displacement Liters (cc) Engine ID/VIN Cylinder Head Bolts Main Bearing Bolts Rod Brearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Lug Nuts Intake Exhaust 2000 2.4 (2389) KA24DE 3.3 (3277) VG33E
all readings in ft. lbs. Year Engine Displacement Liters (cc) Engine ID/VIN Cylinder Head Bolts Main Bearing Bolts Rod Brearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Lug Nuts Intake Exhaust 2000 3.3 (3277) VG33E
1A The cylinder heads and the lower intake manifold are installed together
3C Step 1: Tighten the cylinder head bolts to 22 ft. lbs.
4D Step 1: Tighten the connecting rod bearing bolts to 10-12 ft. lbs.
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 1998 KA24DE
1- Step 1: 22 ft. lbs.
2- 10-12 ft. lbs. plus 60-65 degrees or 28-33 ft. lbs.
3- The cylinder heads and the lower intake manifold are installed together
4- 10-12 ft. lbs. +60-65 degrees
5- Step 1: 72 ft. lbs.
6- Step 1: bolts 11-22 19 ft. lbs.
7- Step 1: 20 ft. lbs.
8- Step 1: 31 ft. lbs.
9- 83 inch lbs.
10- Stud bolt: 11 ft. lbs.
11- Step 1: 72 ft. lbs.
12- Bolts: 17-24 (M8) 16 ft. lbs.
13- Step 1: 33 ft. lbs.
14- Intake manifold collector:
15- Intake manifold:
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 1999 KA24DE VG33E
9- 83 inch lbs.
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 2000 KA24DE VG33E
9- 83 inch lbs.
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 2001 KA24DE VG33E
9- 83 inch lbs.
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 2002 KA24DE VG33E VG33ER
9- 83 inch lbs.
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 2003 KA24DE VG33E VG33ER
9- 83 inch lbs.
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 2004 KA24DE VG33E VG33ER
9- 83 inch lbs.
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 2005 QR25DE VQ40DE
9- 83 inch lbs.
Main Bearing Torque Sequence
Fig. Main bearing torque sequence-2.4L engine
Fig. Main bearing torque sequence-2.5L engine
Fig. Main bearing torque sequence-3.3L engine
Fig. Main bearing torque sequence-4.0L engine
1helpful
Does anyone have the bolt torque specifications for a ford 1995 5.8L. I need the cylinder heads, crankshaft mains and connecting rod torque.
Head bolts, 105-112 Foot pounds (Final torque)
Final torque must be reached in 3 equal steps. Recheck final torque in sequence.
Main Bearing Caps, Torque in sequence Step 1: torque to 50 Ft/Lbs Step 2: torque to 105 Ft/Lbs
Rod Bearing Caps, 45 Foot pounds (Final torque)
4helpful
What is the right Torque Specification of the cylinder head bolt,main bearing and connecting rod bearing for a 1997 Ford F 150 4.2 liter? Thank you...
Cylinder heat bolt torque:
Torque sequence --------- front | 7 3 1 5 | | 8 4 2 6 | --------- Step 1: Torque all bolts in sequence to 14 Ft/Lbs Step 2: Torque all bolts in sequence to 29 Ft/Lbs Step 3: Torque all bolts in sequence to 36 Ft/Lbs Step 4: in the sequence, loosen the cylinder head bolts three turns. Step 5: Tighten short bolt to 15 - 32 Ft/Lbs Step 6: Tighten long bolt to 30 - 36 Ft/Lbs Step 7: Tighten all bolt to 175- 185 degree note: Do not loosen all of the cylinder head bolts at one time. Each cylinder head bolt must be loosened and the final tightening prior on the next bolt in the sequence.
Main bearing torque:
Torque sequence: Step 1: torque bolts to 91 Ft/Lbs with the exception of the rear main bearing cap Step 2: torque rear main bearing cap bolts to 88 Ft/Lbs Step 3: torque brace bolts to 40 Ft/Lbs
Connecting rod torque:
Torque sequence Step 1: Torque to 29 Ft/Lbs Step 2: Turn an additional 90 degrees
TORQUE SPECIFICATION FOR A FORD FIVE HUNDRED OIL PAN GASKET?
Almost all oil pan bolts should not be torqued more than 30 ft lbs. This is to ensure that you don't stretch the gasket and cause leaks. There is no particular torque sequence.
1helpful
Engine swap
What engine? Usually you remove the torque converter bolts through the starter hole.
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
