Dishwashers Logo
k
ken herbolic Posted on Sep 25, 2019
I have a Bosch dishwasher model she23r58uc/64 .... The arms are not turning and the water pressure coming out of the are is about 2 inches high... Cleaned the filter and arms move freely
  • tony denham Sep 26, 2019
    I also meant to say that the pipe to and from the pump may be blocked with grease/filth which builds up over time but failing that it sounds like the pump motor has gone and is running slow.
tony denham
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 34 Answers
  • Posted on Sep 26, 2019
tony denham
Contributor
Level 1:
Welcome Back:
Answers
34
Questions
0
Helped
23369
Points
75
There is often a filter inserted in the water feed pipe where it attaches to the machines valve and is part of the sealing washer, check that is also clear.
5 Related Answers
Anonymous
  • 236 Answers
  • Posted on Jun 16, 2007
SOURCE: Bottom Dishwasher arm not turning
have you seen whether water is pouring out of the bottom supply tube with the lower arm removed? not 100% sure on this model but some units have a half load switch but that should turn off the top one. there may be a blockage in the lower water supply tubeways.
Anonymous
  • Posted on Sep 05, 2008
SOURCE: bosch dishwasher arms dont spin, but turn freely
How do you know the arms are not moving? They are spun by the water jetting through them and they may be blocked. They just pull out and clip back in so run some mains water through them. Also if you put dishes or trays that are big they can obstruct the arms so give them a spin to see first.
Anonymous
  • 42 Answers
  • Posted on Dec 21, 2008
SOURCE: The spary arm on my bosch dishwasher wont spin.
you have a failed circulation pump
Anonymous
  • 105 Answers
  • Posted on Apr 08, 2009
SOURCE: Sprayer arm is not spinning, water comes up through weakly.
your water supply is too low. he watervalve (inlet valve) may be clogged. With insufficent supply you get a low fill and not enough water to fully enage the pump's power.
Anonymous
  • 21 Answers
  • Posted on Jul 20, 2009
SOURCE: Bosch 9925 - water comes in and drains - but not
DO YOU HAVE AN ISSUE WITH HARD WATER IF SO TAKE 1 GALLON OF VINEGAR START MACHINE LET MACHINE DRAIN THEN WHEN IT STOPS DRAINING OPEN DOOR AND FILL WITH VINEGAR THIS WILL PUT ADIQUATE AMOUNT OF LIQUID IN MACHINE TO RUN
DON
262-893-4840
Bosch SMSH63W52N/11 dishwasher not heating water reliably and middle spray arm not turning most times.
It appears that your model is probably SHEM63W52N/01
Bosch cunningly hide the heater inside the pump housing and sell the pump and heater as one unit! Having said that, the heater usually works or it doesn't. When it comes on is controlled by a control unit, another expensive part. I was looking for a relay, but there isn't one.
The spray arms move by the water pressure making them spin. First of all I would remove them and check all the holes for blockages. Replace them and make sure they spin well by hand.
If you are inclined, strip the pump and make sure is is clear of blockages and the impeller spins well. Check the continuity of the heater element.
https://www.appliancepartspros.com/parts-for-bosch-shem63w52n-01.html
2answers
My Bosch dishwasher is not dissolving the tablets now! Any causes?
Try cleaning the pressure chamber and sump hose, if not this , it is not heating ( heater or pcb)
1helpful
Why doesn't my Bosch SHU43 c06uc dishwasher have any cleaning force?
With your dishwasher empty, roll out the bottom rack. The feed line for the upper spray arm runs from a pump outlet directly behind the lower spray arm spindle. This tube runs up the back wall of the dishwasher and mates with the upper rack when it is pushed in.
This feed tube simply snaps into place in the bottom of the machine. It is a high pressure line that makes an immediade 90-degree bend towards the rear of the unit. They have a tendency to pop out. When and if it does pop out you get almost no water coming out of the upper arm and you lose effective pressure in the lower arm, too. The cure is to push that feed tube back down firmly into the port until you hear it snap into place. While you have the lowere rack out it is a good idea to clean the intake screen out and check for any debris in the intake well.
2answers
2helpful
My bosch dishwasher spits out the cleaning tablet and dosent clean the dishes ?
may lack water or pressure. make sure you have 2 1/2 liters of water min, and ck spray arm pressure.
Bosch SHU 8805 upper arm is getting no water.
replace the upper water arm conduit and wash arm hub as they leak under years of pressure and the o-rings leak water and then it can't hold pressure and supply the upper arm with full pressure water,also replace the center arm conduit if it has one as this will wear out too
My Bosch dishwasher, S9J1F will not clean things properly, I've changed the arms, cleaned it. I think the arms don't seem to spin properly, (I bypassed the door switch so I could see them spin)I have tried...
not enuff water in it or pump blockage or bad pump impeller. if you ran it with the door open even if the arms didn't turn you should have got drenched is the bottom covered with water about 1 inch deep some times the fill valve screens get clogged and don't let in enuff water if plenty of water in it look for somthing in the pump
No water pressure in dishwasher
bosch shu5312uc upper spray does not spin. pours water through the center section thus not propelling the arm. any ideas? should the upper arm have any o-rings
Bosch 9925 - water comes in and drains - but not enough pressure to make water comes out of rotating arm more than about 6 inches. Do I need a new pump? I cleaned all holes and filters. How do i access...
DON
262-893-4840
Sprayer arms not spinning
I know this sounds too simple, but on My dishwasher which is an SHX46b model, the plastic supply arm that comes out of the pump and supplies the upper arm popped out of it's correct position at the base. It is held in place by two dinky nibs. I just popped it back in and voila, pressure was back and arms were spinning.
Top Bosch Dishwashers Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
