SOURCE: over heating
OILESS COMPRESSORS WILL HEAT UP MORE THAN OIL FILLED COMPRESSORS,HOW EVER 2 THING'S.CHECK TO SEE THAT THE AIR INLET/FILTER IS NOT BLOCKED OR CLOGED AND MAKE SURE YOU BOUGHT ENOUGH COMPRESOR FOR YOUR USE.HOPE THIS HELP'S
SOURCE: my 1998 atlas copco xas 97 185cfm deutch diesel
Check the Deutch diesel engine controls. Normally with
the compressor at full open, engine must continously run, sionce this is the point where the engine is not
heavy loaded. Check the injection pump as well as engine speed control and the air filter.
SOURCE: air compressor atlas copco ga30 oil seeping out
you should have an oil trap or two in the line from the out let of the compresor before it go's into the factory
they also trap any water in the air there easy to fit into the line and not very pricy
SOURCE: the air compressor xats 67 starts, runs but cannot
suspect that the inlet control valve or control regulator may be at fault, but are you sure that your demand is not more than the compressor can deliver? if you close off the service valve will it come up to pressure and idle back as normal? if so then you may have a leak in your system or your demand is to large. But having a knowledgeable service tech check it out would be the next step.
SOURCE: Atlas copco screw compressor running but not compressing.
what type of compressor, can you please give some more info.?
