Solution 1
Right click on setup file and select run as administrator
Solution 2
- open registry editor, start -> run -> type in: regedit
- Open Hkey_local_machine folder
- Open System folder
- Open Currentcontrolset
- Right click with mouse on enum
- Select Permissions
- make sure user: SYSTEM has FULL CONTROL permission
- See picture:
Make sure system has Check On Allow Full control and read.
Check all users listed that there are no checks on deny.
You can also press ADD to add your own user, then click advanced, then click find now , select your user, click ok, click ok, give your
user full control and read permission.
Apply and ok. double check that there are no Deny permissions set.
let me know the results and do not rate solution untill we have solved the problem.
Thanks,
Ekse
